Lower intake manifold Gaskets
Slyclone
Well-known member
I am going to be doing some work on the truck. I noticed a port which appears to be a EGR port on the lower intake manifold. I am looking at the bottom facing the heads.
Small Oval port. I removed my gaskets last time and that port was blocked from the gaskets.
I remember ordering felpro "performance". I did just buy another set which is identical to the last ones. They do not look like they have provisions for the EGR? port?
Does the port stay open/ get closed off with gasket?
Couger1968
Dazed and Confused
Re: Lower intake manifold Gaskets
I noticed that too. I think being performance they blocked it off. I cut mine open again, just in case I ever get smog checked. My chip closes the EGR anyway, but the intake might run a tiny bit cooler with it totally blocked off.
Slyclone
Well-known member
Ok want to clear something up real quick. I ordered to gaskets from HTP and they were sold as "performance" but they were just the regular 1202's for 4.3l. So not the performance version. I would not know what the difference is between a performance/1202/... other than a port dimension and material/thickness
I do see other gaskets on HTP website which looks like it has a larger cut out for the egr. I dont even know if it matters or is a big concern but when it comes down to it and I see these things I really just wonder if the person I had do this the 1st time should have known this. If the blocked off port cause any problems with the way my truck performed.
Do I trim out a small area so the thing works? Would this hinder EGR function if blocked?
Another quick question is about the T-stat gasket. I use one before and it leaked.(seemed more tricky to get right) I was reading the right up that a member just did the other day.. I had trouble getting the 14's down or the 9/16 right on the one. I actually lost my stubby open end doing the job before. I do have a special dist. wrench that will probably get the job done. Looking into it right now I am seeing what looks like a O ring offered that rests inside the step down on the lower where stat is. Does anyone have any imput on this or has anyone seen or used the o ring?
Couger1968
Dazed and Confused
I ended up putting regular felpro gaskets in. It looked to me the ports lined up better with the regular gaskets, due to the miss match between the port top and bottom. I read a thread discussing intake gaskets, and it sound like people have had luck either way. I contacted HTP and he said I could return them if I wanted, I never did. If you cover the port the egr would not function. My ultimate chip I can turn it off and on, on the move,by switching from stock tune to any other. It never really changed the way it ran, but it intake temps ran much higher with the egr activated(makes sense)and could kind of heat soak the intake after a while. I ran with it off and ran fine in fact it ran a little smoother.
djsy934
[/QUOTE]
That is not an O-ring groove, it is what locates your T-stat.
Aeroking
e.i.
the stock thermostat housing uses a regular 2 bolt gasket (standard SBC). Most aftermarket thermostat housings use a rubber o-ring which sits in a groove in the housing, not the intake. The intake only has a recess for the thermostat to sit in.
