Hu Ryde
I have tried copper rtv sealant, super black silicone stuff. The point is it still leaks from the front and back of the contact points of the motor. Is there anything that can be tricky about applying the rtv sealant? I have proper pcv system currently. Air filter on driverside valve cover and hose to intake on pass side for the pcv. I can see the front of the seal has a leak because oil has pooled up on top near water pump and I can also see the oil bubbling from where it didn't make a good seal. The second time I did this I made sure to put alot of the rtv on the front and back of the motor rails because I was told this was the reason it leaked the first time, because I didn't use enough. Any help or opinions to why it continues to leak? TIA
