Lower rad hose
Re: Lower rad hose
That Summit hose doesn't look right. Just pull your hose and go to a NAPA store and that way you can match 'em up. Be sure to check the water pump weep-hole also (as mentioned in the other thread) my leaked there only when running as well.
Loeryder
Re: Lower rad hose
i 2nd the goodyear hi-miler setup.
I am running the std 4.3 kit and it all clears just fine.
I did some extra trimming in a couple spots just to tighten up the bends.
4C FED
Absolutum Dominium
Re: Lower rad hose
Cover it with some braided steel hose cover or you can use Spectre colored braided hose cover.
Andreas
Re: Lower rad hose
Unfortunaly I dont have NAPA or any other US part over-the-counter-store over here but you're right its the best thing to look at the part in person. The picture in the summit linky isn't the actual part.
Thats exactly whats going on with my WP to. Only leaks when running.
How did you fix that?
Re: Lower rad hose
Actually changing the water pump, once you have one :lol: , is allot easier than it looks. draining the coolant and pulling that lower rad hose is half the battle right there. Just be sure to loosen the clutch fan nuts before you remove the serpentine belt. Remove the top half of the fan shroud and you're there.
Another hint: If they haven't been changed or replaced since the truck was new, now is a perfect time to replace both the idler (plastic:tdown: to steel:tup: ) and tensioner pulleys.
Norm
Re: Lower rad hose
use a sharpie( LOL). Make it any color you want to. No gaurantee on if it works.
Andreas
Re: Lower rad hose
Thanks Don for the hints, but actully Its a 10minutes easy work with the set up I have
Re: Lower rad hose
Well in your case just remove the air filter and yur there. :rotf: Pump looks "newer' is it leaking already? Bummer.
Andreas
Re: Lower rad hose
nah, its just the old WP that was cleaned and painted 3 years ago.
Thats gone be the fix-up for the moment, a old WP cleaned and painted.
Just wanne get my truck running again :)
