lowering blocks
1REDTOY
I had posted before about lowering the rear with blocks and till keeping the wheels centered. I was told to contact 'bigtime' and maybe buy a pair from him. He has none made up right now, so I did research (which I should have done before posting, Sorry) and from that you need to drill out the block and place the pinion block on top of drop block and make a new bolt to lock them together. Well I did this and now my wheels still are not centered. Did I do something wrong or ??? Also I just moved to NJ from Ohio and had the truck emissions checked about two weeks ago the Hydro carbons were 7.8 now I get the truck to NJ and have it inspected and they say they are 282. All that i have done since was a new air filter, plugs, wires, cap and rotor, ign. mod., and a new coil. Any Ideas??
AUSyTyIN
Unbusted $#it box
Re: lowering blocks
Make sure the pin from the leaf springs is sitting in the hole, other wise your alxe will be shifted front/backwards
jwaller
Evil Genius/SyTy Guru
Re: lowering blocks
ya. I made my own after talking with bob. very easy just a block with a hole in the bottom offset from a bolt in the top. if you want a set contact me if bob cant/wont make them for you. check out the pics of my ty in my gallery and you can see them.
jwaller
Re: lowering blocks
sorry but I've been away for a while. Any height block you want will run you $175
