Tooky
Serious about performance
Hi I was wondering if anyone has built an engine with less than 8.35:1 stock compression and if they noted a significant gain in the ability to run higher boost on the street using pump gas? I was reading the Technical articles on www.sdsefi.com and he seemed to be not only very knowledgeable but an extremely strong proponent of low compression turbocharged motors for street use. He even made some extreme theoretical examples of the increase in power seen by running lower compression and higher boost.
I noticed Mike Lee's SRP .030 pistons on sale are actually a 8.00:1 compression ratio which seems the lowest I've heard of. I believe the TRWs everyone uses is actually raised at 8.5:1.
Anyone? And just for kicks, what would happen if you built a motor with 7.0 or 7.5 ish compression? I know TANSTAAFL...
