ls swap here i come
A
amerimuscle99
Guest
Ok so I have decided to LS swap my Syclone. I have a few parts and some one the way. For now though it is going to be N/A until I get everything together I need to start building a turbo kit. I am also staying with the 700r4 until I build the turbo kit then it will be 4l80 probably. What is the most common fuel system everyone is using? 120 injectors and probably a couple E85 pumps.Also ill need a fuel pressure regulater. Ill need lines and fitting for the stock truck fuel rail.
I don't know about keeping the stock tank or getting an aftermarket one. If someone has pictures of sftermarket tanks? Preferably not in the bed.
thanks
CC801
Re: ls swap here i come
Stock tank isn't a problem, I'd always go size bigger than you think you'll need on line, especially if your gonna run e85. 120's are common, make it easy on yourself now and change to an aftermarket rail kit. They can be bought for 120 or less for holley rails. Join tick performances, sponsor pricing club. Well worth the money.
Norm
Change the rail system to a return one, get the street performance kit for the lines or build your own. Get a 4l80-e and do the trans at the same time instead of getting the swap done and then blow up your 700r4. Might cost more in the beginning but then it is done.
A
amerimuscle99
Guest
I might do what I did with my Camaro and have the return off the FPR instead of the rail.
A
amerimuscle99
Guest
With E85 and 120's I am going to do dual E85 pumps. Does a company make a kit?
A
amerimuscle99
Guest
Actually does a company make a full LSX fuel system kit? Maybe not for a Syclone but for a S10.
