I have been working on this car since April of 15. Bravada front clip. L-33 engine. 4L80 trans. 32 spline input shaft from Aaron and I don't know if I thanked him BUT Thanks Aaron. Worked just fine. K&J precision adaptor plate. And a coilover front suspension. All these parts were from members here. Thanks.
Rest of car. Was going to use the frame from the Bravada and stretch it around 8" and run coil overs and a
ford 9" out back but used the donor cars frame from clip back. turned out to be easier?
I figured I could do this in about 3 months. Ha. Everything I touched needed to be welded/drilled/bored/burnt/flattened or bent. And I mean everything. Any modification I did required at least 2 to the surrounding areas which included whatever touched them.
But I'm happy with the way it turned out. Just started it Sat for the first time. Right now i'm having trouble with the converter not unlocking. Chasing wires now.
So here's what I have.
1965 Oldsmobile 442. Original owner. Purchased Feb. 1965. Just turned 50K miles. All aluminum L-33 5.3 engine. Stock engine. Stock exhaust. 4L80 with Bravada TC. 9" Ford rear. Moved engine back around 14". It was either on top of front axle which made it way to high or behind it which moved the engine back which made me cut the floor. What fun.
I did not want to cut up my car at first. But it had to be low like it should be, it's not a truck. So since I've owned this car for 50 years we have become close. I sat in the garage and we talked it over and decided to give the 442 a face lift. :lol:
I'm not to sure of what to do about pics but I will give it a go. Dan.
[/IMG]
This is before. I have to upload to picturetrail to get now pics. dlm
