ls1 corvette alternator connector plug
MIGHTYMOUSE
Turbo F body guy
where can i get one of these please? caspers have a part number or painless or even the gm pigtail part number?
from what i read i need to connect pin c to the old coil wire (or any switched 12v source) and for pin b jump off that but pass through a 470ohm resistor first
comments?
sleepy
Re: ls1 corvette alternator connector plug
I bought an alternator connector plug for my last lt1 swap at napa. I am confused with your connecting it to the old coil wire though.
MIGHTYMOUSE
Turbo F body guy
the old coil wire is just an available switched ignition source
MIGHTYMOUSE
Turbo F body guy
thanks for the link.
its a stock alternator from a 99 corvette
from what i have read, pin c needs a switched 12b supply (what i was going to use my old coil power wire for) and pin b needs this same power but with a 470 ohm resistor as well
