LS1 Harness and NOS System For Sale.
Norm
I have a used PSI harness from my Typhoon for sale. I original ordered a drive by cable harness as I had a 2001 Corvette C-5 engine and then changed plans and went with a built 2004 GTO engine. So this harness is for a drive by wire and for a 4L80-e transmission. I had the ecm mounted on the drivers inner fender. It could work to go back into the original location under the glove box. It is missing a plug from the transfer case as originally both plugs for the speed sensors were the same and with the transfer case/trans they are different so I stole it from this harness to use on the harness I am not running. So if you have some wiring knowledge, you can save a few dollars from buying a new harness . You must also run a green/blue ecm. They are also found on 1 ton trucks. Asking $350.00 and the ride $30.00.
Also have a Nitrous Oxide (NOS) LS1 plate kit . It is missing 4 small parts from it. item #'s : 31-throttle switch bracket, #33- power steering pump spacer, #34 Power steering pump bolts and #39 6an black cap plug. Kit is in like brand new condition. Never been filled, but was installed. Also comes with a pressure gauge. Summit sell them new for $731.95. I'm asking $650.00 shipped in the lower 48. No fees. But donate $10.00 to the syty forum
Any questions ask. I will be shipping these out the weekend I head to Minneapolis for the Back to the 50's car show ( June 20th weekend).
