Re: LS_ or LQ_ w/ 4L60e question
If you put the ls in the stock location, it really makes it tight for the brakebooster, wiring harness, gas lines. A/c box, if you move it 1" forward it makes it much easier to fit. I would flatten the firewall bead cause it will not be long before you need a 4l80e. JTR sells a piece to mod the a/c box. Rpm sells the motor mounts(they are solids) Oil pan is the real PITA.
