lumbar pump
turrrbo6
Has anyone had problems with the hose on the lumbar pump breaking? Mine broke on the pump end and I tried just to slide the hose back on the fitting and it is splitting almost like the hose is too small (probably just too brittle)
Tophatjimmy
Syclone FNG
Re: lumbar pump
Don't have that problem, but I must have a leak somewhere with mine. Pump them up and they go flat after about 20 seconds....sucks. :rant:
V
Re: lumbar pump
You should be able to find a suitable replacement at any good hardware store. Removing the seats makes changing the tubing easier. IIRC, each seat needs less than 3' of tubing. I can get you some if you can't find it locally.
Bill Z
Re: lumbar pump
I have the same problem. So I tried some vacuum hose but it is to flimsy and only lasted a year. I was hoping to find out what you guys came up with. Is there something in silicon that will last?
Re: lumbar pump
Like to get mine working, but I got no pump or tubing and don't even know if it still works! By the way where you located at? I'm in East Oahu
Steve
Ian Turgeon
Cascading Inspiration
Re: lumbar pump
I'll be doin mine in silicone once I get another order o silicone going. Whatever material they used gets brittle very easily.
Bill Z
Re: lumbar pump
Let’s talk silicone.
How big of a group do we need to get before we can realize any savings in buying the proper size of tubing in silicone?
Re: lumbar pump
I'm in for the tubing but need the pumps also.
hatrik8
Re: lumbar pump
I need one pump. Trying to figure out a way to fix it myself. Anyone have any ideas or tried and tested methods?
JJsyclone1128
Re: lumbar pump
quick question, did every syclone come with the lumbar pumps? awhile back i had syclone seats put in my 85 s-15 and they had pumps, but a few years ago i bought my sy, and there arent any, just the fabric loops that hold them in place, did the previous owner remove them?
V
Re: lumbar pump
AFAIK, yes. the hoses disintegrate and pumps jam. previous owner probably didn't bother to replace them.
Re: lumbar pump
The "hoses" probably got brittle and broke, so someone probably removed them.
gkrcr882
SyTyless......for now!
Re: lumbar pump
this is kind of a late reply, but I encountered the same problem. I discovered that if you heat the end of the hose with a heat gun, then inseret a needle-nose pliars to stretch and flare the tube. then I just stuffed the barbed end of the pump/valve assy. and cinched it down with a hose clamp. :2cents:
hatrik8
Re: lumbar pump
FYI I bought a heart pressure tester bulb and and it worked. I had to stretch the tubing to get it to fit with some heat and plyers like gkrcr882 said. I also saw silicon tubing on advance auto parts website. Not sure what size we would need though. They do have red...
