Lumina hood vents
ZavzTy547
Senior Member
Peeps who had these done, how hard was it to install or how much did it set you back to have a body shop install it?
odium
1BADGMC
After you get the vents, you make a template for the size holes you will need to cut in your hood. After you have the template, lay enough tape on your hood to where you won't scratch the surrounding paint when you drill and cut the hole with a sawzall. Go slow and take a few breaks while doing this to keep the surrounding paint from bubbling from heat. Then you need the vents painted, and all you need to do is install them in to the holes you just cut with adhesive or screws, depending on what you are wanting to do.
Somebody on here has a nice link with pictures of how they did it. Hopefully that person posts here.
ZavzTy547
Senior Member
Hey thanks.
I'm gonna put just one vent on the hood, near the passenger side to let the blow-off blast.
odium
1BADGMC
Awesome. Body work is the one thing I can do decently. I got the ty to try my hand at engine work. My last truck was all shaved, painted, modified suspension etc. done by me and a few buddies. Let me know when you decide to do it, I might make plans to come over and help/get in the way.
SeattleSy#1255
Category 5 Conservative
damn you got some balls cutting a hole in your hood. :rock:
I'd like to come...i can watch real good and talk some shit too if you guys want.
ZavzTy547
Senior Member
Ben, I'm gonna start calling you Xzibit, your pimpin peoples rides....
I didn't know you were into custom work. That truck is difinitely in the weeds...Looks good as a lowrider. You did a good job lowering your Ty.
I also want to get my truck lowered a few more inches. so the tires sit closer to the wheelwells like your Ty sits. I'm taking out the stock air ride, putting in some KYB's. I want to replace all the bushing as well, get a rear swaybar and zq8 steering box in the process.
About the Lumina Vents.
I know it's been done a million times but I had an idea of using 1 lumina vent off centered on the hood and a 1-GNX vent on the passenger side fender, to were it will be functional with the KB cold air system (nothing extreme just clean and functional). What about the Range Rover Gills? Naaa......
I need to borrow a cutting tool or were I can rent one in the comming months....
Big Jeff, I may try this on a fiberglass hood?
Latta
Z
Ian Turgeon
Cascading Inspiration
Its funny cause my dad and morgan did the trans am vents at the same time without every having takled to one another. However they both did body work to integrate the scoop. It looks like yours bolt on? How did you end up doing those.
Did you do the same with the hood scoops?
I know I shoulda never posted my lumina scoops :D
SeattleSy#1255
no pics of rolands hood...you'll probably have to just go see it...they are nice.
install is not to bad...what everyone says is difficult is easy and what is suppose to be easy is difficult. the mainfold nuts are easy as are the dp's...people said they are difficult and have to remove a/c compressor which i have no idea why you'd have to do that.
however the simple coolant lines are near impossible and as most would say, removing the dp from the cat is almost impossible in a drivway. I'v torched, malleted, hammered, shaken, jamed with screw driver, and not one millimeter of it will budge.
i'm getting a cutting torch and ending this pathetic battle.
crazykaese
91ProtoTy/IndyPaceTribute & Sawzall Master
The Lumina hood vents are from the 1992 Z34 coupes. The Trans Am fender vents are the same from 1970-1981. All of my vents and scoops were done by my local bodyshop. I supplied them with two complete Z34 hoods and two junk Trans Am fenders. They cut the entire pockets out of all 4 pieces and grafted them into my hood and fenders. The fender scoops and hood vents are bolted into the original framework just like they were in the original factory pieces. My hood is a steel 2" cowl Goodmark piece. The bodyshop had to cut the supporting frame on the backside of the hood and then reweld it to the grafted in pockets to regain the structural integrity of the hood. It took them all summer to do all 4 pieces. I think it was worth the wait.
