Main and Rod bearing question....
MotorMouth
I just picked up my crank today from the machine shop and they had an option to get new bearings with the machine work.
They turned the crank .020" under because of the damage from spinning the to center mains. They did a very nice job by the look of it, I can damn near see my reflection in the journals and they champfered the oil holes. The bearings that were included are made by a company called ACL Bearing Company and the are called Duraglide 780 bearings. The company is out of Australia.
Has anyone ever used these or even heard of them. If so are these bearings any good? Or should I just return them and go with Federal Mogul. Thanks....
Brian
sytyguy
Moderated User
I sell A LOT of ACL bearings (nearly as much as Clevite) and we've never had a problem with them. HOWEVER, the ACL bearings are usually used as a lower budget bearing in non-performance builds. This is due to the price of the ACLs as well as the reputation that Clevite has made for themselves with the aftermarket (most performance guys come in and say, "Hey give me some Clevite bearings for ______."). So, this doesn't give me much feedback for high abuse applications.
All things being ideal, the ACL bearings should do fine for you. Not sure that they have the longevity of Clevite bearings, but I can't see them tearing up any easier than Clevite bearings either (again, all things being ideal = minimal detonation, no cap flex, proper oiling, etc.....).
So........I say use them........unless you have your heart set on Clevite bearings, in which case the machine shop should trade (+ $) without a problem.
HTHs
Hood
sytydvr
NJTy180 said:
just my $0.02, but why even risk using a crank thats been cut, let alone one thats been cut .020 :eek:
I agree get a new crank spend some $ on a new one just 4 insurance
ghettosled
SYTY SUPERSTORE
.010 is fine, but .020 is pushing it. By the time you clean up a used stock crank properly its gonna be .010 anyways. Kinda late now so run it and give us some feedback :) I definately wouldnt waste money trying to heat treat it though.
BigAl...
I've been hearing this CRAP about a crank cut .020 and .010 not being any good for quite some time now. Let me tell ya, you guys are sooooo off base in beleiving that a crank cut 10 ore 20 is no good!!! Some of you might remember in the mid 90's when Crawford Performance came out with the 347 kit for the 302 mustang (I'm not a ford fan but my friend ownes the machine shop that did the machining) before they had cranks made they used a crank from a 351 and cut it down .120 and made tons of power with that setup. BTW a bunch of those stangs are still running around today. So to think that .020 is weakening the crank is ridiculous. I know that our rod journals are off set but keep in mind they are bigger than a 350 journal to begin with! Think about what .020 really is, a human hair is about .004-.006. the most important thing in an engine is the tune. What rattles a crank/bearings? DETONATION! If you detonate I don't care if you have a virgin Billet or a crank cut .060 bad things will happen.
Rant off
BigAl...
ghettosled
SYTY SUPERSTORE
you gotta compare apples to apples. A standard oddfire crank has a rod journal .150" smaller then an evenfire, yet is 10 times as strong. Even an oddfire crank with 2.00" rod journals will be much stronger. Although an extra .010 is practically nothing (mathmatically speaking), every bit counts when guys are trying to push the limits like they are on the stock cranks. I guess it's really up to personal preference, but i would never assemble a customer motor with a .020 under crank. Especially since good cores are readily available.
BigAl...
Ok I just spoke with my buddy at the machine shop, I made a mistake he didn't remove .120 from the Ford cranks he removed .751 on the mains and .290 on the rods and BTW the rod journals on the even fire cranks are .120 bigger than SBC journals. This guy has been in the crank business longer than some of the guys on this forum have been alive. He made it really simple for me to understand. back in the 50's and 60's GM used to harden the cranks and machining more than .020 off of those cranks did make a big difference. The cast iron cranks we have today have the same hardness the whole way through. Again, I beleive with all my heart that no crank will withstand a bad tune!
BigAl...
BTW if anyone is interested in fine machine work www.mesabalancing.com
MotorMouth
Ok, I just got off the phone with the machine shop and they said they made a mistake in wich bearings were to be included with the machine work. They were very nice about it and will have cleavite bearings for me in a few days (no additional charge, yeah!). Cool, taken care of..
I guess I am not quite understadning how that turning a crank down .020" is going to adversly affect the durability of the crank. My motor is going to be mostly stock for performance and am adding the extra heavy duty parts more for personal insurance than to have a killer motor. I know that a stock crank would be gooder but at near 500 dollars from GM the 200 dollars I spent on having the stock crank serviced fits my budget a little better. Mabyee I am just not seeing the big picture (and please fill me in if I am) but I think that a crank 20 under should more than do the job.
Brian
typhoon92
Re: Main and Rod bearing question....
What do you guys think about ACL bearings? Has anyone used them on a sy-ty motor?
TYTILIDIE
METH HEAD
OUCH!!!! My crank was like .40 under. I wonder if thats why it oly lasted 6 months. $500 from GM? I called them redcently about a stock TY cranks and they told me $900. Interesting.
Six-is-Enough
Use to do a little Boost
Brian
It will be fine in your application. If you were running a all out combo then it might be a concern. But in that case you should go to a billet crank and bow tie block. In my race cars SBC we run stock cast Iron cranks turn .030 under all the time and spin them to 9000+ rpm's.:lol: A lot of the engine builders and engine sellers over due some motor parts and pieces. But what due I know I am just "swinging from jeff's nuts".
0260IN3
Engine Builder
ACL bearings in a "P" series are actually harder than the Clevite "P" bearings. We had someone we know concuct hardness testing to find this out. We use ACL's lots in the rods because there are no "H" series brgs available. My motor in my Sy had ACL's and I beat it hard, and no problems.
The .020 crank in my opinion is no problem. Think about it, that's only .010 off each side and like Big Al said these cranks are the same hardness all the way through so it makes no difference. It grinding it .020 or .040 makes it no good, you don't want it in the first place. (maybe .100 off is not so good) The NHRA Prostock guys use 1.88 +/- rod journals and they make 1350HP@10,500 RPM and have zero problems. I know it's not exactly the same, but close.
Be more concerned with proper crank balance, radius on the crank and proper bearing clearance.
typhoon92
Hey thanks Mark,
Do you happen to know the part # on these bearings? How about the main bearings do you use those as well?
0260IN3
Engine Builder
typhoon92 said:
Hey thanks Mark,
The part number for the rods is 6B1358P and add the undersize to the end like 6B1358P20 (.020) Use MS909H20 (.020) for the mains. This is a 350 V8 set so you will have 2 left over brgs, but they are H series. You can use the ACL's on the mains as well but the H's are a little better for high HP and boost. The ACL # for the mains is 5M909P20 (.020 350 set) or 4M1454P20 for the V6 set which you should use cause it's a lttle cheaper and no left overs.
Hope this helps
typhoon92
Hope this helps
Thanks for getting those part numbers!!!!!
sytyguy
Moderated User
Stock bearing numbers:
Clevite - MS1454P - $29.99 set
Clevite - CB1358P - $29.99 set
ACL - 4M1454 - $24.99 set
ACL - 6B1358 - $24.99 set
ACL - 5M909H20 - $48.99 set
HTHs
Hood
