Re: Main Bearings!! Install????
Nope, but I'm fairly sure it can be done. Did you find a bad rod bearing? If so did you mic the crank? I would guess it's one of the two center mains IF it's a main bearing. Could be broken rings, cracked piston to name a couple of other possibilities.
