Aeroking
e.i.
Looking for some info.
First off, i'm checking my bottom end before assembly. Cant get to a parts store to get some plasti-gage. I use it only as a double check, cause i prefer a more precise tool.
Anyways.
I know main bearing clearance should be in the .0020 to .0025 range.
What is the thickness of stock main bearings?
How large should the main bore be?
All my parts were machined together, and i bought the Clevite bearings x909x.
Numbers ended up being.
Main bore with no bearings & torqed main caps : 2.640
Crankshaft journals: 2.449
and Bearing thickness : .090
Now adding up the should give me .011 clearance. when i should be at .0020
any ideas? are the Clevite bearings too thin? did my machine shop over bore the main bore?
i couldnt find any specs for what diameter the main bore is.
Anyways.
