Main caps
Told the machine shop to start on the block today so my question is: Any advantage to splayed 4 bolt caps as opposed to straight which would allow studs. Or do you just put studs in the center? Which works with the stock dipstick? Anything else I should know?
Thanks as always. :tup:
Osmosis
Re: Main caps
splay kits are stronger, also, make sure you have them line hone it and definately use a stud kit!
bezerk
Re: Main caps
with splayed ones, you have alot more body. straight ones will only weaken the bottem
SY2455
70's Veteran
Re: Main caps
X2 on that. I heard that on the 4.3 if you use the straight ones they will crack the block in the area of the second bolt hole for the center caps..
Re: Main caps
Thanks all. I wuz kinda thinkin' that the block was a bit thin where a second set of straight bolts would go. Yes it will be line bored and honed. Will call the shop tomorrow. Curiosity question: Does the notch where the cap sits get enlarged (widened) or does the larger cap sit up on top of the web?
Re: Main caps
Thanks, I was just curious. I'll be chatting with the shop tomorrow.
4C FED
Absolutum Dominium
Re: Main caps
One caveat. You have to massage the cap where the dipstick tube enters the block & bend the tube to get it in. Not a big deal, just an FYI. It's not something you want to try to figure out once the motor is buttoned up & you've got it installed in the truck.
I had to grind a groove similar to the shape of the tube & grand a flat on the washer for that outer bolt.
Re: Main caps
Ah yes, I had head something about this. Thanks for the heads up.
