Upon driving home two days ago I turned the steering wheel to full left lock and the truck instantly died. After straightening the wheel and waiting a minute I got it to fire up long enough to pull it in the driveway. The truck hasn't started since.
After some preliminary testing, I've found out that the truck doesn't get any spark at all. I took the coil wire off the center post of the distributor and put a spark plug on it. It got absolutely no spark while cranking, but it shocked the crap out of my buddy when I turned the key off.
I did a lot of other tests on most of the plugs going to the coil/ignition module/etc., but I didn't really know what I was looking for or what the voltages were supposed to be on each pin at at what time...
My buddy took my ECM out and replaced the chip with the stocker, but I think we're barking up the wrong tree here...
Is there some wire up in the steering column area that could have possibly come undone from turning the wheel? Has anyone ever had this problem? I'm going to continue to dig in that area, but it would be cool if someone knew "The xxxx wire needs to see +12VDC while the truck is running...".
Thanks...
Thanks...
