Making a clean calibration
Buster
Here's the deal, in the past I've tuned my truck at certain boost levels only, and I've have been somewhat happy with the results, but now I'm looking for the perfect chip. I'd like to skip idle, AE,DE for now, and concentrate mainly on WOT at ALL boost levels.
The way I understand it is there's really only three tables effecting fueling at WOT (F30,F61,F77) and a few exception like (coolant temp correction & mat correction), right???
I'm thinking that I should start by making all the values in F61 the same for now, concentrate on getting F30 right (with the wideband) at low boost levels and then increase boost slowly make adjustments in F77, then to finalize it I can make small corrections in F61 for spool up and such..
So far this plan seems to make the most sense, if anyone sees a better/ different approach, I'm all ears!
leroy
Sounds like a reasonable approach. Don't forget the last column of the f29 table is added to f30.
I wish f77 had a little more resolution for a 3 bar.
One of the local dyno shops will have a load control option soon. I think that could speed chip tuning up significantly.
Jim
smeagol
Yea i think that sounds good Mark.
I wish I had more time to work on the single large VE map project. I've got the basics laid out, just need to spend more time on it. Not sure if Dig has done anything with that idea either, as I know he mentioned it in the past.
