Making the BIG purchase, any thoughts?
GM tech
Got some good tips and advice.
Here's what I'm getting today:
Engine and Rotating assembly
Camshaft-RPM's choice w/matching chip and injectors
Timing chain
Dropping heads/intake off for Vortec swap
Roller Rockers/Lifters
Poly motor/trans mounts
ARP main,rod,head and intake bolts
Gasket set
I've already got a fuel pump,AFPR,bigger intercooler/pump and cold air kit.I plan on running stock boost,how much power do you think I'll end up with????Guess's welcome...
QUICK STORM
B.A.M.F. BMW Tech
Re: Making the BIG purchase, any thoughts?
i think mike at RPM should have a good idea, i would definately upgrade the turbo/downpipe, it is now your biggest bottleneck.
GM tech
When I went to RPM today,Mike was also saying the same thing,looks like a turbo just got added to the list.After my wife kills me I'm sure she'll sell it,anyone interested!!!!!
George Blake
DONATING MEMBER
Ask Mike about the poly engine mounts. You may want to go solid. I'm sure Mike does those too. The poly mounts have been known to melt because of the way the exhaust manifolds run really close to them.
NecroWolf
lost marbles member
twin gt35r's would be a good idea w/ a set of brodie heads :tup: :tup: :tup:
