Doug
Starting with a stock ty, here are the parts i have/on their way, am i missing anything?
rpm stage 1 bolt on turbo(would have left stock, but compressor fins bent/damaged from crossover tube breaking, and got a good deal from a member here for a brand new turbo)
garett oil drain hose from rpm
walbro fuel pump
rpm cold air intake to fit their turbo
plugs,wires,cap,rotor, fuel filter
aldl cable
plx wideband
boost gauge
egr block off
3 bar map sensor
turbotweak velosyty chip
already changed all fluids in the truck
am i missing anything major/easy i should be doing? should i get some thermal blanket and wrap the downpipe while i have it off? trying to keep block and tranny stock for now, maybe vortec heads next year. I should be fine with the stock fuel pressure regulator right? At what point would i see benefit from adding meth to the system?
thanks!
-Doug
walbro fuel pump
aldl cable
plx wideband
boost gauge
egr block off
3 bar map sensor
thanks!
-Doug
