marsgmc
yet my syclone now idles rough,stalls and has crappy throttle response.
has anyone also experienced this,does a msd system do the same thing?
i suspect the multi-strike spark signal to the coil is feeding into the injection system causing the problem. also the mallory tech line suggested yhat i increase the base tps volts to "trick the computer" in order tomake it run better. right now im running with the bypass installed.
