manual boost controller question
Sean Donn
this very well may be a ridiculous question but how do you know exactly what boost your turning your ball and spring knob to without having to run it and watch the boost gauge? I have tunerpro rt hooked up while adjusting my boost, however from what i've messed with I can't figure out anything that tells me what boost i'm at.
also one last thing, i've noticed that when turning the bolt and compressing the spring to add boost it takes a lot of rotation to increase boost a small amount is that normal? my bolt only shows about 2 screw treads left after clockwise turning and when doing a WOT run It still only boosts to about 20 psi. is that normal? by the way if any of my reasoning or actions in this comment are retarded I take full responsibility and humiliation.
It's just a six
Super Member
Re: manual boost controller question
You probably need a stiffer wastegate actuator spring. Make sure you are watching for knock/detonation.
Sean Donn
sadly i'm unsure but it looks identical to this
http://www.google.com/imgres?q=ball+and+spring+manual+boost+controller&um=1&hl=en&safe=active&tbm=isch&tbnid=PkpJBvR54gVgMM:&imgrefurl=http://www.mx6.com/forums/1g-faq-forced-induction/119813-building-your-own-dual-stage-boost-controller.html&docid=AKa0pBZTPE2fHM&w=108&h=210&ei=H4ozTr6nN4jagAexhpCODQ&zoom=1&iact=hc&vpx=546&vpy=330&dur=2657&hovh=168&hovw=86&tx=97&ty=98&page=12&tbnh=146&tbnw=73&start=191&ndsp=17&ved=1t:429,r:2,s:191&biw=1280&bih=619
I am wondering if this has anything to do with my lame quarter mile times(fastest of14.3) today at the track. I was running tunerpro rt all day and never had any unusual graphs or anthing, no knock retard, only a code 35 IAC error. from what I could see my boost gauge never passed about 16 for any of the runs
nallj92
you would need a stiffer spring in the valve for more boost, and adjust your wastegate rod also if your having flucuating boost readings.
