Map Sensor Confusion
RAR1TY
Ok... I'm a little confused about my MAP. VinnyTY came down ane plugged in his computer to run some logs on my truck. I bought a Turbo Tweak chip for it, and listed it as "stock" to my knowledge when I ordered it from Eric. I did AFPR, Walbro, Hotwire kit last night. Dialed it in to 44-45 psi, and we drove it around. Now I'm not very up on my computer tuning, but we couldn't figure out if it's 2 or 3 bar MAP. Was stock 2 bar? My MAP has a GM stamp on top and appears factory, but I'm getting code 33 AND 34. What is my truck telling me? Thanks again to Vinny for his help, and to all you guys in advance with this issue!!
Bryan
Re: Map Sensor Confusion
Stock is 2 bar map. An easy way to tell is plug in the map sensor into the electrical connector ( you don't even need to connect the vacuum hose). Turn the ignition on (don't start the engine) and read the factory boost gauge. a 2 bar map will read half way in the middle, a 3 bar will read about 1/3 of scale in the vacuum area.
jaystcb
Sy 0902, 92Ty 0909
this should help if it is a gm map sensor
if it is not a gm map sensor you can do this test.
1) disconnect the vacuume line.
2) Back probe the green wire (b) on the map sensor,
3) turn the ignition to the ACC position.
4) check the out going voltage from the map sensor. Use a multimeter. Set the multimeter to DCV-20. then attach the Red wire to the back probe on the map sensor (green wire, B position) and black to a ground sourse.
Your MAP sensor does not have to be exact to my reading, but should be close.
1-bar MAP TEST
B wire (green)- output wire will have 5.0V @ 0vac.
2-bar MAP TEST
B wire (green)- output wire will have 2.4V @ 0vac.
3-bar MAP TEST
B wire (green)- output wire will have 1.6V @ 0vac.
RAR1TY
Thanks Guys!! It's a 2 Bar, so now I know... Still getting 33 and 34 codes? MAP Pressure High AND Low??? Can it be both? Is sensor bad???
I would check the Map sensors vacuum line, it connects to back of the upper intake mandild and t's to the fuel pressure regulator and map sensor.
RAR1TY
I checked that Vac line and it's good. Just put a new kit in complete. Still trying to figure out why I have 33 and 34 codes. Sending chip back to be set to 3 bar, stock I back in and truck runs fine. So we shall see...
92AcademyPhooner
Don't mean to piggy back off of your guy's thread, but i'm about to install my boost gauge and i just bought a 3-bar replacement. I'm not sure if you guys are familiar with PLX's DM-5 boost/vacuum module, but i don't have to buy that in order for the gauge (which is PLX too) to read my boost right? i can use the 3 bar MAP sensor (stock replacement/location)?
If its not too much trouble can you guys give me a quick explanation on how/where you ran your wires and hook ups from the stock MAP? Sorry to sound like a nube, but just trying to learn. thanks alot.
92AcademyPhooner
you need a 3 bar chip to go with the 3 bar map sensor.
Well, i'm also getting all my code59 parts in as well. I know things will make more sense once i have it in front of me. I've been reading all the installation guides for everything and have been neglecting thought of how the boost/vacuum gets hooked up to it all. I'm gona try and flag down some help on thier forum too, but anything helps. thanks. :)
