MAP sensor harness
Slyclone
Well-known member
Is there a company out there that makes a pigtail splice to extend the map sensor and the valve next to it on the valve cover bracket?
Trying to eliminate the bracket, and the bunch of stuff that I have to attach with it. Might even be the coil bracket ? Its been a while I just opened the hood..
I am using large sheet metal alum. Valve covers but would like to find both connector ends or a supplier to "extend and relocate". I'm sure it makes sense. Many have probably relocated.. I am trying to do this with out cutting any wires .
Re: MAP sensor harness
Shop around. Lots of parts stores carry them also. Be sure to check. The holes are indexed.
