Re: Map Sensor info
It measures the air pressure in the intake manifold. Changes in engine operation and speed will affect the MAP sensor reading, which the ECM uses in fuel and timing calculations.
The ECM receives this information as a signal voltage that will vary from less than 1.0 volt at closed throttle idle, to 4-4.5 volts at wide open throttle.
If the MAP sensor fails, the ECM will substitute a fixed MAP value and use the Throttle Position Sensor (TPS) to control fuel delivery.
