MAP sensor question
Damian
For as long as I can remember, my idle has always been a little rough. I replaced my knock sensor last night and when putting the front nut back on the MAP/ coil bracket, I accidentally pushed the MAP plug off. Started the truck up and it sounded different but idled better. I had Datamaster on it and my O2 sensor readings were all over the place with the MAP sensor hooked up, very steady with it disconnected. I have the 3 bar MAP from Hood with Hood's tune. Any ideas?
Also, how do you clear the codes on Datamaster? Even though the CEL is off, the codes still stay on in the Datamaster screen.
Thanks.
Damian
Re: MAP sensor question
With the MAP disconnected, the afrs stay steady too. "Normally" they range from 14.3-15.3, mostly they hover right around 14.7. Disconnected, it stays at 14.7. I'm assuming MAP is bad?
Jimmy
Banned
What codes? Have you reset the IAC? No vac leaks right? What's your vac reading @ idle?
The o2 is always gonna be all over the place FWIW. Until you get a wide band.
Damian
I had Code 34, and 43. 34 was from me disconnecting the MAP sensor plug on accident, and 43 was from me buying an AutoZone knock sensor and replacing it a couple times before, I have an ACDelco in there now, correct part number.
Vacuum at idle is -18 to -19 via AEM TruBoost gauge. I have a wideband, just not using code$59.
I cant get the codes to clear with TunerPro, not datamaster. I cant even get datamaster to work on my laptop.
Ill try the IAC, just need to find the procedure again.
Jimmy
Banned
To reset the IAC:
With the engine warmed up and the truck shut off,jumper the 2 top right ports on the ALDL.Turn the key to on (you should hear the IAC spinning.)Wait 30 seconds,then turn the key off.Remove the jumper.Pull the ECMB fuse out then put it back in.Start the truck.It should find it's own idle
Your vac readings looks spot on BTW.
Damian
Im gonna replace my vacuum lines again with new T's and what not. Didn't replace the fittings last time.
Jimmy
Banned
Hell no.You got good vac.
Don't throw parts at it. We can figure it out.
Just need data.
Oh hell,you live close to DaveP,he can fix it. 26 miles from you :tup:
Damian
I could ask Dave, but that's all I do is ask him questions. I could buy him lunch again.
I tried the IAC reset and its back to the same. I checked all the vacuum connections and nothing bad so I didn't replace them. The only thing I've done that helps is raise the idle to 900 in park. 750rpms at idle and the engine dies in gear.
Jimmy
Banned
Dave likes answering qustions.I'd buy him lunch and pay him to fix my truck if I was lost as last years Easter egg.
