March Performance Pulley Part Numbers
mrweelr
Looking to replace my ugly stock pulleys with some lighter March pulleys. Can someone confirm these are the correct bolt-in replacement pulleys for our trucks?
-3 piece power and amp set. alt pulley w/ nose cover, crank and water pump pulleys part# 4465 recommended for auto trans vehicles.
-Power steering pulley #610
-Idler pulley # 725
-Tensioner pulley # 710
Are these the exact same ratio as stock or are they underdrive? I see "power and amp" in the description and I don't want to lose amperage. Also, if anyone has pics of these installed, that would be much appreciated.
ed hess
race or get outta the way
Re: March Performance Pulley Part Numbers
if you look real close you can see them in this pic.
not sure about the part numbers
Merk
ed, your engine bay reminds me of that one scene from Terminator 2: Judgment Day!
Mmmm...shiney! :tup:
4C FED
Absolutum Dominium
What!! No AC clutch cover? :D (hint #376)
All of those numbers are correct. It's the same stuff I've been running.
The crank pulley is a reduction pulley, but they make up for the loss by reducing the alt. pulley diameter so it spins the same speed it used to with the stock pulleys. So, if I were you and you plan on buying that kit, install the alt. pulley.
Holy mackerel Andy! (It helps to be old to understand;) )
What a gorgeous setup.
mrweelr
I ordered all of the March pulleys from Summit Racing and it came out to $422 delivered. They do look sweet and should drop a few lbs. off the truck.
Quickstop [UK]
Combating adversyty.
What is the part number for the belt now? A stock one is too long as the crank pulley is smaller, but the a/c delete pulley is too short.
Quickstop [UK]
OK - for anyone else with this issue:
I rang March Performance and they said it was a 91.5" 6 rib serpentine belt P/N 4060915.
END OF SAGA
March also told me to try a 93.5" and the directions in the box are misleading as well. I ended up getting a 90" belt and even that looks a bit loose to me.
not running a/c but if your set up is like this . bought it at o,reilly will go out and get #
Quickstop [UK]
So I have been running a 90" belt and that works fine.
I recently tried to install the pulley for the PS pump. What a disaster.
I pulled the stock pulley off - so far so good.... In trying to install the billet March one, the installer stripped the threads off the snout so I had to replace the pump. They were stock so undoubtedly foulled from years of being on jackstands.
I heated the March pulley to 400 degrees and it still didn't slip over the snout, even after I filed the inside down.
A brake cylinder hone from Harbor Freight is too large so I had to use sandpaper. I'm going to a machine shop tomorrow to get it honed professionally.
This has been an expensive lesson in vanity - 65 for the pulley, 45 for a new pump, 20 in assorted hand tools that didn't work, a lot of gas to and fro and finally my time.
I am out $130 for a shiny pully. :rainbow:
Audio Man
I just did my power alternator and water pump pulley underdriven. The rest are stock size although I did put a new power steering pump pulley on and ran into the exact same thing you did, stripped inside so it just pushed the install tool out instead of pressing the new pulley on so I had to replace the pump like you did.
Are you running an under driven crank pulley as well. I was going to as I have it but heard of guys having charging issues when they swap that one so I left it off.
What belt are you using. I saw 90" but was there a part number or vehicle you got it from. Or just randomly try belts till one worked?
I wasn't going for any HP gain or performance gain out of this, just liked the way the nicer aluminum pulleys looked and cleaned up the engine compartment a little.
Quickstop [UK]
Hi there,
Yes, I decided that I wanted the whole look so installed the underdrive pulley. It hasn't made any difference as far as I can tell but my plans are to put the larger CS 144 alternator in that I have lying around anyway. How much electrical load do you have?
I can't remember the length of the belt - it's been a few years. I think the 90" one was the last time I tried it. I may even have just parked at Auto Zone (scary) in the hood in Wilmington, DE, and tried a few random ones. I don't think the underdrive made a huge difference to the length.
Sorry I can't be more help. :dunno:
Slyclone
Well-known member
I recently installed a MARCH kit on my truck. I ended up buying 2 kits because I buy everything 2x. The first kit was not for the application. It was a kit for a 305/350 camaro which has the same 6 rib setup it is just the crank pulley is different. Spaced further out
My second, part # 4310 was the correct kit for the truck application. 1988-1995 GM truck. It has the Alternator, Crank, And water pump. The kit I got had a bonus which was the extra power steering pump pulley and a fan blade.
The belt number provided on the list is 4060930/ 6PK2360. I did some cross referencing and I was able to source a very nice good year gator back 6 rib belt for cheap. I did want a OEM GM belt but it was not correct in sizing.
