Master Cylinder Replacement Questions
Syclone#1992
SyTy.net Moderator
Here's the deal. Truck is all original, including the ABS. Most people would tell me to ditch the ABS, but I want to keep this truck as original as possible.
That being said, I discovered that the bottom of the master cylinder might have a slow leak. I guess my question is, when swapping the master cylinder out, is there a proper procedure, to bleed/prevent all the crap from going into the ABS unit?
Any good places to buy a master cylinder?:tup:
Thanks,
Tim
NJ93TY
Re: Master Cylinder Replacement Questions
When I replaced mine I got one from the dealer. Its pretty straight foward, first evacuate the old fluid in the resevior as much as you can. Dissconnect the lines/electrical connectors/ nuts and remove the cylinder. Bench bleed the new cylinder with clean brake fluid, reinstall it and bleed it where the lines go into the cylinder. Carefull not to spill too much brake fluid. Once your done, road test and check for leaks.
