Max current?
Quickstop [UK]
Combating adversyty.
What do you guys think the max current draw would be with:
PCS 4l80e trans controller
WBO2 (PLX DM5)
Alky pump (Alky control)
I have a relay and I'd like to power all three off it but am worried the draw might be too much for the cables.
Do people run multiple appliances off a relay or do you guys use one per item for signal noise?
I am sure 30A relay would be fine - it's the cabling I'm concerned with. I'm trying to clear up under the dash.
92TYPHOON937
Re: Max current?
i would make them seperate so they cant interfere with each other especially the wideband and the pcs controller
