Max Hp on this Bowtie block?
ed hess
race or get outta the way
robert
I seem to recall hearing that the aluminum block isnt going to take the torq. i may be wrong but at real high levels you would need motor plates as i was told the motor mounts would be flexing the block in the middle.
the other isssue i was told was getting clearances for aluminum (heat expansion) was going to be difficult as not enough experience and info.
i think i heard that waller built one awhile back, drove it to the dyno, tested it, and on the drive home it came apart!
perhaps you could ask john what issues he found.
i think i also recall hearing 600hp was about the limit.
note that everything i am telling you is just the nonsense i heard and none of it may be correct.
ed
NOJIMMY
....Robert, check out the following link detailing a build:
http://popularhotrodding.com/enginemasters/articles/chevrolet/smallblock/0305em_mmouse/
The history of aluminum-block engines seems to be full of disappointment and premature failure
owing to warped cylinder heads, leaking seals, blown gaskets and worn cylinders.
Some require a half-quart of oil between oil changes every 4,000 miles."
All GM production engines use cast-iron cylinder liners, either pressed or cast into
the block. That ensures that even with aluminum blocks, the pistons and rings get the
benefit of iron's hardness. Despite advances in aluminum engines, they still cannot seem to
withstand overheating, contaminated oil or dirty coolant the way cast-iron blocks can.
The most serious problems with engines that use aluminum have come from two sources:
designs that match aluminum heads and cast-iron blocks, and those that do not use cast-iron
cylinder liners. Aluminum heads mated to cast-iron blocks require carefully designed head
gaskets. Ford Motor Co.'s 3.8-liter V-6 engines, for example, have a history of blown head
gaskets and have been the subject of a contentious recall.
Then of course there are expansion, lubication, heat and tolerance issues.
jwaller
Evil Genius/SyTy Guru
Re: Max Hp on this Bowtie block?
mrsyclone said:
http://paceparts.com/index.asp?PageAction=VIEWPROD&ProdID=22324
/Robert
that is a better version of the one I am using. with that being said I had a problem with mine eating up the bearings after 1000 miles. come to find out it had some problems unknown to anyone before it came apart.
FWIW I will be using my same alum block in the truck when the motor goes back together.
