max lift on L35's
Re: max lift on L35's
Lift mostly depends on the springs. I am just guess based on my expereince with FI SBC, but you usually stock spring it probably around .450-.460 but you should make sure it doesn't have coil bind.
tippmann243
i was asking because i know the 96> vortec heads are only good .470" and you have to maching the spring seats and change springs, just trying to figure out if i have to do this with the L35 heads too
NecroWolf
lost marbles member
you might try a beehive spring they're suppose to allow you more lift
sleepy
I have a comp 422 cam with 1.6 rockers and had to have the top of the guides machined just a little to get the correct clearance. 422 specs are .500 intake and .510 exhaust.
I also got the beehive springs, but the lift issue was the valve keeper to guide clearance. Hope this helps you out.
