Maximum injector size with stock ecm?
TurboTony
Okie, just a few questions for the tuning gurus.
I know that 50's are the largest high impedence injectors that are available. But if a person where to change the drivers anyway, would it be possible to run say a 72 lb/hr injector.
I know lotsa GN guys use 55's and a few have tried 72's. Not sure about the sucess rate of that though.
I figured since our ecm's are faster than the buicks it might be a possibilty.
Of course these would require custom w/b tuning to figure out.
Brian, Nolan mentioned that you tried 55's before going speedpro, how did you find they worked? I see that Jim is running 55's although in the early stages.
Phewww, thats it for now.
TurboTony
smeagol
Once you change drivers, you should be able to run 72s, 83s..whatever. I have faith that you could tune 72s on the stock ECM. Buick guys are running 83s on the stock ECM.
I think there would be some key things to change in the calibration (not meaning just the VE etc) if you ran such a large injector, but it could be done. The 55s shouldn't be that difficult (relatively) to tune. The peak and hold setup is better anyways...
TurboTony
Thanks Brian.
Nolan mentioned that the peak and holds usually are a more stable injector, guess that would help too.
I should fill you in on the fuel system as well. I was gonna go the double pumper route but plans have changed.
Bought an aeromotive A1000. Gonna sump the tank and run a 10 feed line and a 6 return through custom rails and an aeromotive A1000 reguator. We figured as long as I was upgrading I might as well go all the way.
Might switch to a 72 turbo as well, not sure yet.
Whats your thoughts on injector sizing, are the 55's enough, or should I just get the 72's while I'm at it. Found a used set of 72's for $300.
Thanks again
TurboTony
leroy
I bought Roland's 55# injectors. I think he went to 72#(SpeedPro). He felt he was running out of injector with his setup. He was at 80% duty cycle before he got a whole lot of boost. I think he has a TE72?
Brian, what key things do you think need to be changed for the big injectors?
Jim
TurboTony
Hey Jim, could I buy those extras drivers off you. Or can I just get the part#, might be able to source them out here.
Also, any extra instructions or advice would be great.
I think this is the way I'm gonna go, to poor to afford FAST so...
Tony
leroy
The part number is a Fairchild Semiconductor HUFA76429P3. I got some free samples from Fairchild by applying through their web site. I wish I had asked for more. You may have to embellish your request a bit to get them. :wink:
There is a plastic piece that bolts against the drivers. Remove it carefully. You may have to use a knife. Scrape away the coating from the solder connections. Desolder the drivers. There are little beads on the driver "legs". Make sure to get the beads back on the new driver "legs" in the same position. Put the new drivers in. Use the plastic piece to hold them in place, then solder, trim off excess. Put everything back together. Carry some extra fuses for ECM-1 until you are sure everything is working okay.
Jim
TurboTony
Thanks for the info Jim.
One more silly question, how many do I need? I mighta found them locally.
TurboTony
TurboTony
Thanks again Jim
Is there anything you have to change code wise to run peak and holds? Or does the driver do the high/low current switch on its own when the injectors are cycled?
Man I have about 1000 questions about this driver change, we gotta get icq working, or better yet AIM
TurboTony
kwick6
On 2002-02-22 00:06, sy2173 wrote:
Document this and we'll put it up on the web. :smile:
Take pictures and stuff.
Thanks
Yeah and ditto for the diy-wb 02, :wink:
Thanks,
Scott
TurboTony
I would love to help others with the diy w/b deal. But keep in mind i'm no electronic expert.
Nolan and I will take lotsa pics and take some notes. At the very least it will be a dummies guide to diy w/b.
I'm really pumped about this whole 72lb deal. It should be way more injector than I ever need.
TurboTony
kwick6
From what I have read about the peak/hold injectors they sound really nice. Should give a nice sharp open and close, and better idle, off-idle. They operate at a lower pulsewidth, so there is less *flooding* as they open/close.
diy/wb02... I will need the dummy version please. So please be as thourough as possible. ;P :smile:
Scott
TurboTony
Don't worry, it will be the dit w/b for complete f'n electronic morons :grin: :grin: :grin:
Hope I remeber sumthin from that grade 10 electronics class I took :razz:
TurboTony
kwick6
Jim sent me this awhile back, and I saved it in hopes to someday try this myself.
The mosfets are the injector drivers.
Here are the steps for the swap...
The best way I have found to r and r the fets is as follows.
1. Scrape away the coating on the bottom side of the circuit board around
where the fets are soldered to the ECU.
2. Remove the solder from the leads of the fets and printed circuit board
3. Remove the bracket that is holding the fets and other devices to the heat
sink. First remove all the screws holding the plastic retainer, then pry it
off slowly and carefully. Try not to break it.
4. Make sure you have most if not all the solder holding the fets into the
printed circuit board removed. After you remove the plastic bracket you
should be able to wiggle the fets out of the printed circuit board.
5. There is a little bead that is attached to the fet but may stick to the
printed circuit board. MAKE SURE YOU INSTALL THESE onto the new fets. If you
do not the car will run real bad and you will get the CES light flashing
from all the noise. These beads prevents the high frequency noise from
reaching the CPU circuitry.
6. Place the fet into the holes on the circuit board that the olds one came
out from. DO NOT FORGET THE BEADS!
7. Center them up and reinstall the plastic retainer to hold them in place
while you re-solder them.
8. Cut off excess leads length, reinstall cover and re-wire the ECU to run P
and H and you will good to go.
Thanks agian Jim.
Scott
TurboTony
Okie, I understand most of that.
Gotta go buy a soldering iron and a solder sucker.
But whats involved in rewiring the ecm for the peak and hold injectors?
TurboTony
leroy
I did nothing to rewire the ecm, except plug the connectors back in. I had some concerns about the injector wiring and harness being able to handle it, but so far so good. No excess heat noted. No smoke let out. In fact, the ecm seems to run cooler than before.
As I mentioned before, I blew one ecm-1 fuse early on.
Jim
B
Blake
Guest
Don't mean to ask a stupid question but can this mod be done for the sake of installing larger injectors in the future? I ask this because I may do this while I have everything down putting in my wide band and serial interface setup for datalogging. Have to hit the junk yard so I can have a spare ecm to dork up :D
Thanks,
Blake
myclone
Blake,
My understanding is that you can mod the ECM for the bigger injectors but still run the stockers with no prob if you want to upgrade later. If my research into the specs on the drivers is correct the drivers for the larger injectors just have a higher current capability that will handle the low impedence injectors current requirement.
B
Blake
Guest
Thanks, David. You keep it up and your gonna get a guru status at this stuff. :wink:
Blake
