MEL210S Hits the pan
Aeroking
e.i.
my combo is a M55HV pump and a 210S pickup, on a stock rear main cap.
and it hits the pan, big time. it might work if the risers werent in the bottom of the sump. but the pan wont even sit on the pan gasket.
Help.
sy#2921
BAMF
Re: MEL210S Hits the pan
Time for a BFH. I had the same issue with my pan. Had to bend the pickup slightly with the gasket off to get it to sit correctly
4C FED
Absolutum Dominium
That's normal with the HV pump since it's .25" taller that the stock pump.
You'll have to either modify the pickup or pound the bottom of the pan to make enough clearance.
Aeroking
e.i.
tips on modifying the pickup !
do i need to break the brazing on the screen, and roate the tube, or should i bend the tube?
Aeroking
e.i.
decided, i'm just gonna cut the bottom of the sump outta 2 pans, and make 1 deep pan.
i'll post pics if anyone wants to see.
Ground Rat
I'd like to see some pics, please.
Aeroking
e.i.
i decided to cut the pickup instead of the pan. so i'll take about 3/8" outta the pickup tube, and TIG it back together. that'll give me the 1/4" of vertical clearance i need.
also TIP. the body of the M55HV hits the pan also. the pass side of the pan sump side needs beat out with a hammer also. just a FYI
