Re: melling oil pump picture thread
Melling Select 10552 10% higher volume - standard pressure, 3/4" inlet.
259 pick up screen assembly 3/4" for 9-1/4" deep oil pan, oil cooler and remote oil filter 4WD.
The pick up must be shortened 1/2" to fit the oil pan because the Melling Select 10552 oil pump housing is .487" longer than a standard volume or stock oil pump.
1992 and later Chevrolet 4.3L V6 oil pumps have a 3/4" inlet.for no more than 5% higher volume than the standard 1985-1991 oil pumps that use a 5/8" inlet. . Chevy 4.3L V6 engines do not have priority main bearing oiling like a SBC V8 engine and the front main bearings on the V6 engines can fail at high RPM (5000+ RPM) due to lack of oil volume. For anything except a grocery getter, the Chevy 4.3L V6 engine needs 10% higher volume and a 21 PSID oil bypass valve in the block. The 21 PSID by pass valve is GM 25014612. The Chevy 4.3L V6 engines came with 11 PSID by pass valve because those engine were red-lined at 4700 RPM with a standard volume oil pump. .
Using a higher volume oil pump is especially important on vehicles with an oil cooler and/or remote oil filter. The stock 11 PSID oil pressure by pass valve in the remote oil filter adapter on the left front fender is not a problem and does not need to be replaced with a 21 PSID by pass valve for high performance engines. . .
