Melting aluminum heads?
Methuselah
If our EGTs are between 1100* and 1300*F (from the EGT sensor discussion), then why isnt this a problem for those of you running aluminum heads? Combustion chambers are even hotter, right?
The melting point of aluminum is about 1217*F.
________
BABY MAC
leroy
I expect the heads are an aluminum alloy that has a higher melting temperature.
Jim
Tooky
Serious about performance
Where is this EGT discussion? I think it is time to have another one. I was reading the fantastic tech sites for the Turbo 4-cyl Dodge fellas and their comments on the EGT sold me on the idea. Sounds sort of as good as a WB-O2 except it's something I can actually use! :smile:
RAACCR
I guess you're assuming that the heads get as hot as the EGTs? They don't; neither do the pistons. The burning air/fuel charge is very hot during the power stroke, but that only lasts an instant...a fraction of a second later, it exits out the exhaust, and a new cool air/fuel charge enters the cylinder. The metals don't get as hot as the gasses...the hot gasses aren't in there long enough to fully transfer their heat to the metals.
