Melting plug wire boots
roswald21
So I'm on my third set of plug wire, this last set is 10mm and I have the fiber wrap on them still I can smell them burning. Any ideas I have read remove the cat and check if I'm running lean. Any other ideas. I plan to have the wide ban in this weekend.
Ty 1885
Re: Melting plug wire boots
What brand of wires are you running ? I had the same problem with MSD wires years ago.
T-Bone
I bet you are running headers. If so, buy you a set of ceramic boot 8MM plug wires. They run about $150 -170 but are worth it in the long run. I put a set on my built Sy with the additional protection of kevlar heat shields and it runs awesome!
roswald21
There owl 10mm burned IL two sets of msd and one kennel bell set. I have the boot protection on there. Just the two front ones melt.
roswald21
Well cat got removed today and no melting boot wire smell I will take it for a longer ride tomorrow and see how it goes. That cat was definitely restricting the TY
If you plugged up the cat, most likely you have an issue with your engines tune that caused that condition.
roswald21
Im sure it was clogged cause it ran great. I still get more surging than usual
qbnkiller
Conflaguration Specialist
I had similar issues until I bought a set of custom-made FIRECORE50 wires with the PROMOD boots. No more socks and no more burning.
