mercruiser motor information?
Status
Not open for further replies.
angel
BIG ANGEL!!!
did these motors came with steel crank?are the heads any good for sy-ty? just bought a long block .with a small crak on the side of the block. :roll:
angel
BIG ANGEL!!!
Re: mercruiser motor information?
so no body know about this motor? has any body one of these motors? halla back ;)
ty166
looks like i'm not the only one that forgot to drain the water from my boat motor befor winter set in.... lol
angel
BIG ANGEL!!!
im going to use it on the truck .it will get repaired. just need to know if someone out there is using marine motor on there truck?
angel
BIG ANGEL!!!
Re: 4.3 mercruiser motor information?
IM GOING WITH IT . :lol:
angel
BIG ANGEL!!!
4.3 Mercruiser ?
4.3 Mercruiser ?
I WANT SOME GOOD INFO ON THESE MOTORS, I WILL LIKE TO BUILD 1 FOR THE STREET . INFO ON THE CRANK,HEADS,BLOCK? OR NOT :rant: !!!!! LOL, MERRY CHRISTMAS :lol:
Enough with the 4.3 Mercruiser Threads! This the third thread you have made, you only need one :rant: This is the small forum and not alot of us (if even any) have much experience with them. If the motor is cheap enough pull it a part and tell us what is has.
ty166
when i was looking for 3.8 chevy info for a boat i bought with a rod hanging out of the block and wanted to bolt in a 3.8 malibu motor found all my info at the mercruiser site and dealer, maybe they can help.
SOME DIFFERENCES BETWEEN AUTOMOTIVE & MARINE ENGINES
For those of us in the marine industry, a common occurrence is to be questioned by customers about auto vs. marine parts. A common scenario is to have a customer ask for a replacement part for his boat. The part in question is a starter for a 350 cu.in. GM block. You give the customer a price, and he looks at you with a blank look on his face. He, then states (very angrily) "I can get one at the local auto retailer for $29.95".
In the marine industry, this little scenario occurs all the time. Many boaters are unaware of the difference between an automotive and a marine engine and their respective accessories. The most notable differences include the exhaust systems, the cooling systems, the electrical systems, and the fuel systems. Additionally, items such as heads and cams are usually different. For the purpose of this article, we will only be hitting the highlights on select systems.
In regard to the cooling systems, one of the major differences is found in the water-circulating pump. This is especially noticable when you have a raw water cooled engine. Unlike their automotive counterpart, a marine pump works in an open cooling system. This type of system is extremely corrosive to the pump. Therefore, the pump must be altered for longevity. A marine pump has a special ceramic seal, stainless steel backing plate, and a bronze impeller to resist corrosion. An automotive style pump, with its stamped steel impeller, would fail due to corrosion in a short time.
The electrical systems in a marine application are also extremely specialized. In an automobile, any gasoline vapors that accumulate will readily dissipate through the bottom of the engine compartment. However, a boat with its sealed engine compartment, does not have that luxury. Therefore, any spark could literally cause a boat to explode. All electrical components in a boat are either completely sealed or specially vented to prevent such a catastrophe. This includes the starter, alternator, distributor, and many other engine electrical components.
Carburetors typically have what is known in the industry as J type fuel bowls. These allow for the extreme vibration, pitching and yawl experienced on boats. This allows fuel to be drawn in exteme conditions and keeps fuel from being ejected from the carburetor barrels.
Heads and cams are set up for a completly different torque curve. A marine engine must develop most of its torque on the low end of throttle range. This allows for the ability to use a single gear transmition system. Think of it this way:
You get in your car
Start it up
Drive to the highway
Put your foot to the floor and hold it there for an hour
Its a little different, well for most of us.
Although we have only briefly touched on some of the differences between an automotive and marine application; hopefully, it will serve to remind us that there is a difference, and that the reasons for these differences need to be shared with our customers and friends in the boating community. Hopefully, when shared, this information can eliminate some of the "blank stares" in regards to parts, and maybe prevent some dangerious situations.
from http://www.marine-engines.net/topics/001183.html?motors
and
http://www.gm.com/automotive/gmpowertrain/engines/specialized/marine/2006_4300_marine.pdf
angel
BIG ANGEL!!!
beacause once i had a marine bbc427cu. and that never gave me a problems on da street , and it was bore out to .60 over w/ 10.5.1comp.990heads and mild cam for NOS,10 inch converter on 700r4 ,with my 65ssmalibu , I LOVED THAT COMBO. so thats why im asking about these marine 4.3. i know they crack when they dont winterized them on the boat . but i herd good story about marine engines .
TYTILIDIE
METH HEAD
As far as Ive known, the water passeges are copper inside and thats about the only thing that makes them different is the water jackets. They are set up to cool better I think and I believe they are also plated inside with copper, or aluminum, somtehing like that. There is absolutely NO reason why you would get any better strenthg out of it. Im sure youve probably heard that Corvette motors were marine engines but they werent. If thats what you heard that made you think this do your homework. It doesnt make a bit of difference. Now if you threw a reg motor in a marine app, You wouldd probably have issues down the line.
ty166
the blown 3.8 i removed from a boat had nothing diffrent interanl that i saw as far as any coating , the cam when checked against a automotive cam was very diffrent. head casting number were the same boat motor to car motor , actually i threw a bone stock car motor in the boat just because , took forever for the boat to plane out and lost oil pressure by the middle of the lake and the row back put me in the hospital. personally i think i would steer away from a used boat motor because its probably spent 95% of its life above 3500 rpm.
jjorgensen52
NHSTE - I'm the only one!
They are in fact a different block material. They also have stronger rods and rolled fillet cranks. Just so you know :tup: . My GT is getting a brand new marine 4.3 ... which has already got vortecs, the better rods, a 250 hp cam, and full roller valvetrain... straight from GM ;)
bezerk
i like to put airplane engines in my trucks, they really Fly!
TYTILIDIE
METH HEAD
Thats a crock. That may very well hold true with some but I can garunfriggin tee not many are going to have better rods and cranks. Ive been around boats for a while and will admit I dont know everything about them but have been inside some friends boat motors and saw NOTHING special. For all the bullshit time you spend fartin around with one why not just get a normal 4.3 do what youre gonna do with it and call it a day? And BTW, if there was anything special about a 4.3 that was used as a boat motor, it didnt come that way. I just got back from the machine shop getting a tensioner made for a board memeber and asked about it and even they said out of all the 4.3 boat motors theyve had the only differences they know of is things like seals(some) and head gaskets.
You guys sound just like the people that think they know about SyTy's.
Research people. Google is your friend.
This is straight from the horses mouth:
MEFI-5 (Marine Electronic Fuel
Injection - Fifth-Generation), is an
advanced engine controller capable
of meeting all the emissions, OBD-II
and driveability requirements of
marine applications.
Vortec™ 4300
The Vortec 4300 V-6 gasoline engine
features overall size and weight
advantages with superior power-toweight
ratios and proven durability.
The marine industry’s
only production 4-cycle
fuel-injected V-6 engine
Features & Benefits
¶Integral Air Fuel Module (IAFM) inlet manifold
with port fuel injection
¶NEW: Cracked powder metal connecting rod
(interim 2006) to more accurately position
the cap to the rod during engine assembly. A
high-flow cylinder head with straighter intake
ports and a higher compression ratio delivers
impressive horsepower
¶High-silicon cast aluminum pistons offer
excellent durability
¶Roller valve lifters, roller rocker arms and true
roller timing chain for reduced friction and
improved performance
¶Composite rocker arm covers and front cover for
reduced noise and resistance to corrosion
¶Cylinder case has brass water jacket core support
plugs for resistance to corrosion
¶Water pump is effective rotating in either a
clockwise or counterclockwise direction
¶Nodular iron crankshaft has rolled fillets for
increased strength
Marine Engine
¶An electronic control module (ECM) and related
hardware are available in kit form. The ECM uses
state-of-the-art technology to optimize fuel and
spark requirements.
¶A 2V inlet manifold is available.
¶EST and HEI distributors and coils are available in
kit form.
Available Options
2006
2006
Vortec 4300 Feature Focus
GM Powertrain takes its expertise in designing
outstanding Vortec truck and SUV engines and
leverages it to make sophisticated yet extremely
durable marine engines. In addition, the wellrecognized
Vortec brand name by itself has
become a valuable selling tool for OEMs.
The Vortec 4300 marine
engine uses advanced
technology to maximize
the simple pleasure of
boating.
Hydraulic roller valve lifters
and roller rocker arms help
provide smooth, quiet and
efficient operation.
A counter-rotating
balance shaft cancels
the primary engine
vibrations found in 90°
V-6 engines. The result
is smooth performance
and low noise.
The new Integral Air Fuel Module (IAFM) incorporates
several features into one integral assembly. The bottom of
the inlet manifold is made of iron and the top is made of
aluminum. Integrated into the module are a stainless steel
fuel rail, stainless steel tip fuel injectors, and a throttle body
that includes a Throttle Position Sensor (TPS) and an Idle Air
Control (IAC) motor.
Stainless
steel fuel
rail
Stainless steel tip
fuel injectors
¶Cylinder head gaskets have stainless steel core for
corrosion resistance
¶Cast aluminum oil pan provides increased strength and
noise reduction and is chromate conversion coated for
corrosion protection
¶Nodular grey iron bearing caps
¶Metric fasteners on engine mounts, starter bosses and
bell housing
¶Eccentric main bearings for increased engine life
Additional Features
All GM marine engines are Vortec™ engines. Vortec
means uncompromised power — outstanding power
with no sacrifice in fuel efficiency or durability and
very little required maintenance.
2006 Vortec 4300 4.3L V-6 (L35, LG3)
0
100
200
300
400
500
0 10 20 30 40 50 60
ENGINE SPEED (rpm x 100)
TORQUE (lb-ft)
0
50
100
150
200
250
HORSEPOWER (hp)
226 hp
268 lb-ft
546.61
(21.50)
283.09
(11.15)
255.05
(10.04)
543.30
(21.39)
645.43
(25.40)
A4c.t3uLa l LpoGw3e Mr leavreinlse may vary depending on OEM calibration and application.
Specifications
2006
© 2006 General Motors Corporation
PRINTED IN U.S.A. 1/06
www.gmpowertrain.com
GM Powertrain
Type: 4.3L V-6 Gen 1e
Displacement: 262 cid (4294 cc)
Engine Orientation: Longitudinal
Compression Ratio: 9.4:1
Valve Configuration: Overhead Valves
(2 valves per cylinder)
Assembly Site: Romulus, Michigan
Valve Lifters: Hydraulic Roller
Firing Order: 1-6-5-4-3-2
Bore x Stroke: 101.60 x 88.39 mm
Bore Center: 111.76 mm
Bore Area: 486.44 cm2
Fuel System: N/A
Fuel Type: Regular Unleaded
Horsepower: 226 hp (169 kW) @ 4800 rpm
Torque: 268 lb-ft (363 Nm) @ 4000 rpm
Actual power levels may vary depending on OEM calibration
and application.
Fuel Shutoff: OEM Defined
Shipping Weight: 449 lb (203 kg)
Emissions Controls: N/A
Materials:
Block: Cast Iron GM232-M
Cylinder Head: Cast Iron
Intake Manifold: Cast Iron
Exhaust Manifold: None
Main Bearing Caps: Cast Iron GM232-M
Crankshaft: Nodular Iron
Camshaft: 5150 Steel Billet
Connecting Rods: Powdered Metal (interim 2006)
Information may vary with application. All specifications listed
are based on the latest product information available at the time
of publication. The right is reserved to make changes at any time
without notice.MEFI-5 (Marine Electronic Fuel
Vortec™ 4300
Features & Benefits
increased strength
Marine Engine
spark requirements.
kit form.
Available Options
2006
2006
boating.
A counter-rotating
the primary engine
and low noise.
Stainless
steel fuel
rail
Stainless steel tip
fuel injectors
bell housing
Additional Features
0
100
200
300
400
500
0 10 20 30 40 50 60
TORQUE (lb-ft)
0
50
100
150
200
250
HORSEPOWER (hp)
226 hp
268 lb-ft
546.61
(21.50)
283.09
(11.15)
255.05
(10.04)
543.30
(21.39)
645.43
(25.40)
Specifications
2006
GM Powertrain
Fuel System: N/A
and application.
Materials:
Vortec™ 4300
Features & Benefits
increased strength
Marine Engine
spark requirements.
kit form.
Available Options
2006
2006
boating.
A counter-rotating
the primary engine
and low noise.
Stainless
steel fuel
rail
Stainless steel tip
fuel injectors
bell housing
Additional Features
0
100
200
300
400
500
0 10 20 30 40 50 60
TORQUE (lb-ft)
0
50
100
150
200
250
HORSEPOWER (hp)
226 hp
268 lb-ft
546.61
(21.50)
283.09
(11.15)
255.05
(10.04)
543.30
(21.39)
645.43
(25.40)
Specifications
2006
GM Powertrain
Fuel System: N/A
and application.
Materials:
without notice.
there
Status
