Methanol Injection kit from Summit Racing
Hi guys, I just got a new catalog from Summit Racing and on page 40 they have a methanol/water injection kit made by Snow Performance. Is this unit ok for our trucks? It has a 150-200 psi pump,built in check valve ,2qt reservoir, adjustable boost pressure switch,three nozzles,hoses,wiring and states that its for engines with 8-30 lbs psi boost.
It also includes maf digital variable controller. Sells for $389.88. I have just started to read about alky injection and all that I have learned has been from you guys on this forum. I plan to purchase it or a similar kit for my truck. I want to turn the boost up and do it safely. My goal is to run low 12's, or possibly dip into the 11's with my stock motor. I have installed lots of new performance upgrades and with only a few other items left to buy. I will be ready to start tuning. Truck has never been to the track, but that will change when it re-opens in the spring.
I will be needing lots of advice once I'm ready to start tuning. Is there anyone who is real good at tuning our trucks who lives near me? I'm located in Nanticoke , Pa. near interstate I-81. I donot have any tuning equipment but will buy if neccessary. Who wants the job? I keep reading about Dig, but I think he might be too far away. I have a heated garage but can't drive the truck till we get some rain to wash the salt off the roads here.
martygar8
syclone #1322
Re: Methanol Injection kit from Summit Racing
hey i got the methanol injection for my sy from snow performance and runs real good, i was just wondering what mods did you do to yours, mine is plain stock and i would like to run in the 12's but still wondering what i need, chip, fuel pump injectors, not to sure what to buy and just wondering what would be a good combination, but back to the methanol im using windsheild washer fluid and got great response but gonna try straight methonal, which some friend of mine that has a grand national, using straight meth is the way to go, you can't beat it, lowers your intake temp, and boost your octane, and some say that there knock counts go way down, safe so you won't blow that engine, but good luck and let me know :tup:
I have a low mileage (21k) truck. I started with a 3" ss converter with a 3" catback with borla xr1 sportsman muffler. The truck had never been tuned up so I purchased the sy/ty tune up kit that has the 8mm wires,brass terminal dist cap/rotor and also plugs which I gapped at 32 for now. Next, I purchased the walbro fuel pump and the racetronix wiring harness for it.
Next came the billet fp regulator and I have it set at 50psi for now. I picked up an Ultimate chip for stock injectors from a board member. Its the radar style and I mounted it under the dash with velcro because I didn't want to drill any holes in the truck. I have the 3bar map,and a K & N filter in the stock air box.
I have insulated the stock air box, cross over tube, and the under side of the upper intercooler. Oh, I almost forgot. I installed a johnson pump for the intercooler and a 90 degree fitting on one of the lines. I also cut out the front of the stock air box and got some polyurethane sway bar bushings along with lower bump stops,gauge pod with autometer fuel pressure and boost guages.
With these things done, I 've played around with 17 and 18 psi a couple of times on the T1 setting on the Ultimate and the truck really moves now. I usually keep it on 15psi for safety. I just got my stock turbo back from the shop. I sent it to Tim's Turbo in Virginia and had a 20g upgrade done. He used to own a Typhoon and if familiar with sy/tys and set mine up so that it will work well with the stock converter. It is clipped and he said its somewhere around a 11 or 12 cm. I don't know really what that all means but it's installed but I have not driven it yet due to there being a little snow and salt on our roads.
I have been copying everyone elses mods from this forum and next will come the alky kit and hopefully I will have it tuned by this spring. My truck runs real good with all these mods and I sure hope to get some nice time-slips at the track. My brakes also hold very well. I can build lots of boost but since the turbo upgrade, I don't know.
Flyin Ryan
hated cuz he drives fords
