metric conversion
les
does anyone know the conversion for kPac to pounds. I bought an autoxray scanner and it's giving me my boost in kPac. what does 70kPac convert to in pounds of boost? Bad news is my boost is way down, good news is at 4400 rpm knock is only 1 degree
0-60N4
boost pressure
boost pressure
Les just installed the ultimate with 3 bar MAP sensor. He just got the Auto X-ray also. Can the auto x-ray read the difference between a 2 bar and a 3 bar MAP sensor? If not, his boost reading on the auto X-ray will be incorrect. Am I correct? He says the truck is running much stronger than when he had the stock chip and stock boost so I don't think he is really only running 10 psi (70 kpa) of boost. Doesn't he need anothe conversion for the 3 bar sensor?
Jim
Coloty
Kpa x 0.1450= PSI
70 Kpa x 0.1450= 10.15 PSI
Not sure if the X-ray knows how to convert from 2 bar to 3 bar like datamaster does. Might be an issue, but the conversion formula is correct and air tight.
0-60N4
convertion
convertion
I agree with that conversion. I just question if the kpa reading from the auto X-ray is accurate. I don't think so, therefore some additional conversion would be required. Les, can you determine if the auto x-ray has 3 bar capability?
JIm
Coloty
Well just messing around with Datamaster. I pulled up a run taken on a truck with a 3bar chip and the ultimate. PSI was at 10.1 PSI with it set to 2bar. When I placed it in 3bar (as it should be) it went up to 15.9 PSI. So, I would bet the Auto X-ray is wrong and that the actual boost is around 5-6 PSI higher than the 10.15. Not too scientific, but I think it tells us what we are wanting to know.
les
metric conversion
metric conversion
First of all, thanks to all of you for trying to help me! Jim, I can't find out anything about whether it will convert 2 bar to 3 bar. I was thinking of calling Brian Hartman (you listening Brian?) because I believe he has an autoxray as well as datamaster to see what he thinks. It would be nice to know if I'm getting 15 or 20 pounds though.
Les
JoeLutz
If you are running a 3bar sensor and the scan tool reads it like its a 2bar sensor, then just multiply the reading by 3/2 and it should be pretty close to the actual value.
