Mightymouse AC delete, broken belts
Anybody else that has done this have issues with belts not lasting?
I cut my own brackets, otherwise used the same tensioner, location, etc.
2 belts shredded now. 1st time 2 miles, found "some" mis-alignment and made an adjustment.
2nd belt after 30 miles or so took it apart, belt looked fine, tweaked alignment a bit more. Around 100 mile mark, belt #2 shredded.
I end up with 2 ribs of the belt still good, the rest is just strips, like you ran it through paper shredder.
I am sure its an alignment issue, but damn is it picky. Both times I was just driving not in boost or anything.
I am using a belt 57.5" in length and have 2 more on order (they are not off the shelf size). The tensioner is just about perfect centered with a new belt so I don't think its length issue.
It almost looks like the tensioner is able to "twist" on the bracket either due to bracket bending (its .25 thick for most of it, .5" thick near tensioner) or the bolts are just not holding it flat up against bracket.
Just wondering if anybody else is having issues.
MikeRenz
not stock
Re: Mightymouse AC delete, broken belts
how tight is the belt getting from the tensioner? maybe a slightly shorter belt would do you some good...or add another set of bolt holes to the bigger bracket to allow you to tighten up more on the 57.5" belt.
The other holes are there, I just dont think thats it I think its "moving" around allowing pulleys to get out of alignment which is why it "shears 4 of the 6 ribs so I end up with 1 LONG strand about 200" long.
MikeRenz
not stock
hmm...wonder if the bolts holding the tensioner on are bending under pressure....making the pulley go off-perpindicular...and is eating into the belt.
what grade bolts are you using?
MIGHTYMOUSE
Turbo F body guy
post a pic of your set up. i'll help if i can. i don't get the whole shredding thing.. normally they will just pop off if the allignment is wrong. i assume you have the right number of ribs and rib profile? k6?
I have my exact stuff (a few sets) laying around if you think its worth a shot ill ship a set at cost... maybe your metal is not exactly the same thickness as what my shop uses or something.
also is your tensioner brand new or used? maybe its worn out and the slop is letting the pulley pull out of allignment when tensioned?
also check where the bracket mounts to the water pump.. there may be some clearancing to get the bracket to sit totally flat on the face.
Very much my :2cents: since I'm only looking at pics but I would take a look at the support bending like you said. Stick another belt on and rev the motor watching the tensioner. Another idea (again I only have pics to go by) would be to turn the bracket around so the tensioner ends up on the pas side. If it'll bolt up and you can find the correct length belt it might be worth a try.:roll:
Chest Rockwell
I've got my bracket flipped, since I wasn't able to find the right length belt otherwise. No problems so far with belts, though I did lose a couple of upper hoses due to no upper fan shroud to hold it off the belt. My setup doesn't have any additional support brackets, and I'm using a new tensioner.
I have ran all these through my head. Its true .25 plate, I cut it out with plasma cutter, smoothed, drilled on mill, etc. The first belt I actually put a washer behind tensioner as it appeared it needed a slight shim out to line up with other pulley. After 1st belt I rechecked that and removed those washers. Obviously this has helped since the belt lasted ~100 miles vs 2.
Running it through my head today I think there are possibily a few issues. The biggest I think is the bracket flexing some, or the tensioner to bracket bolts flexing as per what Dave and Mike are suggesting/thinking.
When it flexes the belt then gets off track, it then very quickly slices the first rib then turns the next 4 ribs into 1 long string, when it gets to last 2 ribs just not enough belt left so that "flys off" as a seperate piece.
I am 80% sure they are grade 8 bolts, need to verify.
The tension is brand new, belts brand new. All the other pulley spacing are unchanged from what has worked for several thousand miles before AC delete without issue.
Once belt flys off you can visually see the tensioner is not aligned, so the bracket is moving some and Dave's brace idea may be ticket.
Last night we drove it around without issue, but it was raining so I am thinking the water helped the belt slide vs shear. This morning when I started it I did hear a belt squek, so thats a sign also.
Just bugs, i will figure out something today or tomorrow for sure.
95xtreme
I basically built the same style mount with an ls tensioner on a v8 s10 I was working on. I did basically what Dave was talking about, if you look I ran a brace from a bolt hole on the front of the intake to the top bolt on the tensioner . You could not flex this think if you tried now.
The only difference between this set up and yours, is these are 416 heads which do not have the inner accessory head bolt hole like the newer v8's, or 4.3's have. That's why the one bolt is spaced so far out.
TYTILIDIE
METH HEAD
Vasplieon version is my favori9te. Been running it since the new build with 0 issues. No bracketry PERIOD. Drill two holes and you are done.
Another thought; if you're just eyeballin' the alignment you might try a straight edge. From all the way across one pulley over to the other. You might be surprised.
Just got truck in garage, got a new belt to put on to look at it.
From this pic and from my eye it looks like the tensioner is forward of the alternator. The issue is when I take belt off and no tension it seems to be fine.
Truck isn't at my house right now, and couldn't find a straight edge although I did straight edge it the other day at my house. What I am suspecting is happening is under tension, load, etc the tensioner bends forward. This obviously is a problem.
Looked tonight on how to brace it back to intake and I see a couple ideas, just gotta get truck back to MY house where the tools are not the girlfriends.
I also bought the tensioner for the other version and probably drill some holes for that way also, AC bracket has to come up and again tools are at my house. So looks like tomorrow might be go get trailer day -vs- chancing another broken belt.
It is .250 for most of it, .50 behind the tensioner.
Obviously its not thick enough or something.
95xtreme
i like this version! Even less bracketry than the mighty mouse version...which was already pretty slim.
Thanks, it works out pretty slick. The one I am doing now for a 4.3 is even cleaner since it does not have to be as long.:tup:
MIGHTYMOUSE
Turbo F body guy
should be 3/4" on the tensioner side
original.aspx
if it doesn't look like this.. then it needs to.
if it does look like this, then something isnt lined up right.
also it just struck me.. your truck is a v8 right? who knows where the front of the casting is on the water pump relative to whatever bracketry is holding your ps and alt.. i assume using the stock syty stuff?
Yes its a v8., stock syty brackets or they were at one point.
The .5" spacing is REAL close I think the issue is where the bolts go to attach to water pump, the bracket in that area has to be so narrow to clear water pump casting it easily bends forward putting tensioner out of alignment.
The thing is when the plate is "in flex" as shown it's not as strong. It'll bend one way easy and not at all the other. IOW that plate needs a rolled edge to strengthen it. (I think that made sense.) IOW the tensioner is "pulling" the plate in it's weak direction.
So I'm thinking that under high RPM load it bends a bit further and shreds the belt.
Just thinkin' out loud.:roll:
