Mileage per tank?
Quickstop [UK]
Combating adversyty.
What are people getting from a full tank of gas? Mine is in km but I am only getting around 300km. I am not sure if something isn't amiss.
Robert Lone
MUTANT
Re: Mileage per tank?
I'm getting about 18 months and a thick coat of dust from a tank of gas.:rotf:
At least the jackstands work! :tup:
SBNova
I get about 260-285 miles per tank. That was on its maiden voyage home when I bought it.
sytyguy
Moderated User
420-480 depending on how I drive. Of course, I did a lot of chip work to get it to this point.
Hood
sytyguy
Moderated User
That's 186-ish miles. That's definitely not good (9.3 mpg if that's a full tank).
Hood
live1053rulz
Nor Cal SyTy
Hood
Jeez, I want to get some custom chip work for that. That's freakin' awesome, I'm still around maybe 240 for a full tank.
gjp
another post whore
I would guess around 240-260. I never let it get much below 1/2 tank. At that mark I am around 140 or so. I average 12mpg street and 16mpg hw. I always keep track of miles driven/gallons
92boostedty
Senior Member
so what are the main causes of bad gas mileage? besides making boost...does having a high volumn fuel pump make it use more fuel all the time or just when you need it? thanks
93TyGuy
Boost Freak
gjp said:
Driving habbits. My right foot weighs 200lbs. :)
Yours too? glad I am not alone. I got about 200 to a tank but I drove it so hard the motor let go. :rant:
live1053rulz
Nor Cal SyTy
:werd: I'm pretty much exactly the same. Plus the 200lb foot thing...
NecroWolf
lost marbles member
i got about five blocks and some idle time on the last three or four gallons i put in cause of a map sensor
sytyguy
Moderated User
Are you guys using american gallons? That is 3.78. Rest of the world is 4.344
Yes.....US gallons. I doubt you'll find many of us living in the states using any other type of measurement considering this is a domestic forum.
It's all relative to your first question however (What are you guys getting on a full tank of gas?). A stock tank holds about 76 liters of fuel regardless of the unit of measure used to pump it into the tank. You get 300km (186+ miles) per tank while an average, stock SyTy should get around 550km (340+ miles). No matter how you cut it, 9.3 mpg (or 8.1 mpg in non-domestic units) is bad.
Hood
