min voltage for ecm operation.
Hello everyone. My 92typhoon typhoon has hot
restart problem. Cranks fine hot but no start. I captured
It occurring using datamaster and noticed that the
ECM voltage was near 8-9 volts while cranking.
Is this to low for proper ecm operation? If I wait 5-10
Minutes ir fires right up.
I have an ostrich/moates setup with new stock ecm.
I am also considering using a remote relays to directly power
the ecm A and B bypassing the factory harness.
Thanks in advance for your replies.
Static
Re: min voltage for ecm operation.
Do you have a fuel pressure gauge? I had issues with 2 or 3 of my cars where the check valve was going bad in my fuel pump. Fuel would bleed back to the tank after I drove it and let it sit for 20 or so minutes. Next hot start try key on just to run the fuel pump and off then back on again 2-3 times and see if it starts easier. If it does try replacing the fuel pump.
Also do a search for the voltage mod, it increased the voltage to my ecm especially under WOT and also my truck idles better now. It cant hurt.
Thanks for the reply. Yes I do have a gauge.
It seems to stay in the 40psi range. I will give that
method a try the next time it happens. Thanks
for the tip on the voltage mod, will search to find
Out more.
