What controller are using? I've used each of the following 3:
- Air Compressor Regulator
- JoeP MBC
- JoeP EMBC
- The regulator had very good control, regardless of the vac line size.
- The JoeP MBC never would get consistent with 5/32 or 7/32 vac lines.
- The JoeP EMBC is a little better than the MBC in that it is consistent, but still suffers from big changes in the controller.........meaning, the controller may allow 12psi and one push of the button will then allow 19psi. Just too big of a change for one push of the button.
I have a feeling that there needs to be a specific size vac line for the JoeP setup. Not sure how others are running it, but I've used 5/32 & 7/32 lines with minimal luck. I currently have the EMBC installed and have managed to get a solid 16psi on the current setting, but one push of either button results in either 10 psi or over 20psi.
Not trying to hijack the thread, but if anyone has any input on this, I'd be interested.
Hood
