Miss fire on launch
Skinner2013
Re: Miss fire on launch
No gauges on the truck ��. Come to think about it only started doing it after I fixed two vacuum leaks. Do I need to get the truck tinned? If so any ty runners in Phoenix Arizona area?
Skinner2013
One line that was t off on the egr valve which gave me a high idle and the second line which on drive side a black box with two hard plastic lines coming out of it
Skinner2013
Since I replace the two vacuum lines stock boost gauge does go past 15psi. All lines to boost control is fine. Under normal conditions truck runs great only if from stand still it does it. Weird lol. Possible over boost?
RealFastV6
@jb_and_his_coffee
You have to get a real boost gauge.
All stock without the cat, good chance you're just overboosting.
