Missing FP@WOT
0966Sy
Code what?
When i go WOT in my truck the FP only rises to about 60-61psi from 40psi. I have my FP set to 50psi base, with a Ultimate made for a stock truck at T1-16. The boost control is accurate, and with 16-17psi(boost) at WOT in T1-16 im only seeing 60-62psi at most with an external FP Ashcroft guage. I thought at 16psi of boost with your FP set to 50psi base should be at 66psi @ WOT am i correct? I believe my truck is leaning out somehow. I am in the process of getting Datamaster in about 1 month. I am having trouble shooting for causes. My mods and repairs below.
56k on truck
Stock Ultimate Chip
12'' 2800 stall
ATR exuast
ATR cold air
Accufab AFPR
Walboro 255 pump
jabsco IC pump
3/4 heater hose mod for IC
Stainless turbo to IC pipe
All new vac lines
no vac ball
no ABS
no EGR
no cruise
new o2 sensor
new fuel filter
the truck awaits datamaster
Thank you for any help or idea's.
Erik
0966 Sy
JoeLutz
Very carefully check vaccum lines for leaks starting at the back of the manifold and where it tees to the map and the FP regulator. Could be leaking under boost but not vaccum. Take the line off the fitting on the manifold and apply presure to it to see if it leaks down. If you have an external pump, do yourself a favor and ditch it in favor of an in tank Walbro. Externals just don't work as good IMO
Falco
Erik,
I had a similar problem a while ago. My one was cured by the replacement of the O-rings through the whole fuel system. Tank assembly, filter, regulator.
Checked your vacuum lines first as JoeLutz said. I also put a little O-ring gasket under the locking nut of the regulator's adjustment screw. If this doesn't help try the O-ring stuff. Also be aware that the leak can be at your gauge too...
HTH,
Maxtor
Erik -
You have 50psi base fuel pressure, I assume adjusted with the AFPR vacuum line disconnected and plugged- correct? Then you re-connect the vacuum line - you no longer have 50PSI - mine drops to 40 something.
"Base" is without vacuum applied to the regulator. I see about the same readings you do at 16PSI on my electric in-cab gauge when I set the regulator to 50psi with the vacuum line removed and plugged.
You may want to stay out of it until you can verify with Datamaster/Diacom what is really going on. Your Walbro pump and Accufab regulator should be more than sufficient for your setup.
Maxtor
Ok, I've slept since that last post. I see what you were saying now - Vac line off represents 0 PSI to the actuator, set to 50 psi base, add 16 lbs boost, FP rises approx 1 lb with each 1 lb of boost = 66 psi fuel pressure.
Like I said before, datamaster/diacom are the key to understanding your truck. My two sy's are so different I often wonder if they were really made by the same company..... if your fuel pressure is too lean you can get some pretty serious knock. Be careful.
0966Sy
Code what?
I do set the FPR at 50psi "base" without vacume. With vacume it decends the FP about 10psi. It has to be leaning out at WOT due to the missing 5psi FP. It only gets to 60-61psi when it should be at 66psi with 16psi of boost. I was leaning torwards getting the injectors checked out and flow matched. Instead i've taken the route to upgrade to 50lb Delphi's. I am not going to try to turn up the FP to compinsate for the missing FP at WOT, It would only foul the plugs and would be to much for the stock injectors. Soon enough i will have a laptop to use datamaster on and i will try to find the culprit if the Delphi's dont cure the problem. I will have my mechanic troubleshoot the fuel system when i take the truck in to have the 52 turbo and down pipe installed. I may have to try the O-ring idea from Falco, but the truck only has 56k and dont see why it would need it. But then again it is 11 years old.
Thanks for the idea's
Erik'
Sy#26
Erik - do NOT do any mods until you find out what's wrong first - its only gonna get worse if you do; you can't "mod" your way out of trouble. You've got inadequate fuel w/ the stock, 29# injectors and you want to use 50s that need MORE fuel???
Your first $$$ needs to be data logging - period. You're totally in the dark w/o that; that's part of the price of going fast and should be your FIRST purchase.
I would suspect the fuel pump first - did you get rid of the pulsator during install? Check the FPR for leakdown & pump also - if you don't have a manual to see how to do that, get the CD. I lied in the above paragraph - *that* should be your FIRST buy.
The less you rely on others, i.e., mechanics, the better able to fix your own truck & get a much better handle on the how & why of these beasts. Mechs that know SyTys are rare as Unicorns - beware.
FWIW, etc, and I'm sure no expert....
Barry
0966Sy
Code what?
Today i removed the Ultimate and 3 bar map, to try out the stock chip and see how it would handle FP with the 2 bar map with fuel pressure@42psi Base. The fuel pressure is now at the correct level at WOT. So why? who know's. I realy need to get a hold of a lap top, already have the software,cable's for DM. But what do i look for in DM to find the culprit. Could now having the coorect FP at WOT with the stock chip mean i for sure dont have a leak anywhere. I need DM to find out if it is a knock related issue.
Erik'
Sy#26
Sounds like your fuel pump can't handle the additional 8-10psi raising the base FP requires. Either a weak pump or a leak internal to the fuel tank. Pulsator removed per the pump install instructions? Leading cause of low FP. A good 255 pump will do it easily; I run 55# base on my 40# injectors, good to over 25psi boost, no FP fade at all.
Barry
Have you run any xylene since you last fuel filter change? Mine got clogged up from the Xylene cleaning out the tank.
0966Sy
Code what?
I did not install the pump myself on my truck becuase i had no help to pull the bed off the truck. So i paid Conley's here in houston to install the pump. I know the pulsator was removed becuase it is still attached to my original stock pump. One time i was setting the fuel pressure with a buddy's mechanical guage and it ended up the guage was reading 10psi rich then the actual fuel pressure. Thus caused the fuel pump fuse to blow because it was at like 60psi Static. I have a walbro 255 pump but would blowing the fuse for the pump would have messed somthin up. I must have used a total of 10 gallons of C16 through the truck within a period of time. But i was mixing it with 93 to come up with 105-110.
So can a walbro 255 pump take the abuse i've put it threw with a little leaded gas and blowing one fuse. I hope the pump isnt bad.
Thanks'
Erik
