Finally believe I've gotten the most out of a 40# chip; my goal was to get some good (& safe) performance out of this size injector, mainly because "nobody has a good 40# chip".
Build is:
1991 ported Vortecs
Isky 252/257 cam
TE60 / Mitsu 14cm, WG by Chan to 1.43"; 20psi set pressure
Base FP = 62psi
Methanol / water injection, 25% v/v ratio to fuel - only 93 octane pump gas used as fuel, no race gas
Built trans, 9/11 converter; 5300rpm shift points
600+ chips burned, on my third engine in a year....
My tuning baseline is 0 - 90mph on a country road; tracks around here closed for the year. Best time this afternoon was 6.40 secs, 0 - 90mph, non-launched, just floored off the line.
Have NO idea what this would work out to for a 1/4 mile time & speed; maybe someone w/ some datalogs of fast runs could give me some idea.
Gonna get some 50# injectors now; not going for any more power, just safety; injectors are static over 5000rpms now, hit 90% D/C @ 4300rpms & 18psi. AFRs per FJO wideband run 12.2 - 12.5 @ WOT, zero knock everywhere.
Barry - Sy#26
Bangor, MI
Build is:
1991 ported Vortecs
Isky 252/257 cam
Base FP = 62psi
Barry - Sy#26
Bangor, MI
