mistakes you made building your engine :)
ed hess
race or get outta the way
Since I am in the middle of this now and i just made a mistake of using oil on my head bolts instead of thread sealer.....
I figured this would be a good time to make a collection of things you did by mistake so that others (LIKE YOURS TRULY HERE) would have the benefit of knowing what not to do.
YOu should only list things that you actually did, or are absolutley sure that someone else did.
Who knows Y'all might be able to help me or somebody else save their butt with this one (not to mention a lot of time money and aggravation).
ed
I'll bet this thread is gonna get really interesting to say the list!
Ok guys confession is now open!!! roflmao
typhoon1588
figuring that the forged pistons could wait until the summer while the rest of the rebuild went on...
needless to say i drove the typhoon 1 time over spring break and killed a piston. my dad is taking it out and mailing it up to me - i will take some pics and show you that if you give one of these trucks an inch, they will ALWAYS take a mile!
sytyguy
Moderated User
The machine shop made a mistake on my first engine and installed the rear cam bearing improperly. Oil pressure was almost non existence, and I lost a new turbo quick-like with that engine.
Had a buddy that thought you had to turn the engine over while you plastigage'd the bearings. Didn't live too long that way. No, this buddy wasn't me....really.
Oh yeah, torquing the rocker arms down doesn't work too well. Not that I know that from personal experience or anything :wink: .
I've been lucky otherwise thus far.
Michael
MikeRenz
not stock
I initially lubed the front and back of my main bearings when i first was putting my block together.
Then i realized it was kinda dumb and started asking around to see.
AUSyTyIN
Unbusted $#it box
When I was building the motor for the SS, I put the pistons in with the valve reliefs facing the wrong way.
sytydvr
make sure there is little play on the piston floating pin and connecting rod I almost made that mistake... My engine assembly balancer guy informed me and enlarged the hole a little.... If its too tight your piston rings will be gone before the engine even breaks in
hope that helps everyone
Joe
sy#682
ty#2351
E-Rue
if you remove the distributor, when you reinstall it, make sure it drops all the way down. if it doesnt, when you fire the motor you will not have ANY oil pressure.
e
myclone
Aligning all the piston ring gaps.
Swapping upper/lower main and rod bearings.
Using hydraulic lifters on a solid cam to try to tame it down.
Breaking a head bolt, drilling it, then retapping the hole only to break the tap, getting frustrated and just leaving the broken tap in the hole (massive coolant leak).
Putting a junk yard carb on a new engine just to get it fired only to have the float stick WFO which hydro locked the engine with fuel. Then dicking around with it some more and catching the fuel on fire that was pouring out of the headers onto the garage floor.
ALLWAYS getting the distributor "one tooth off" or "180 out".
I could go on but this board only has so much bandwidth.....
leroy
After I put everything together it wouldn't start. I got underneath and shorted across the starter. It fired right up, but was in drive. I made it out okay, just before the car ran into the barn wall.
Jim
Jim
Ouch.. reminder to self, Jim only has 8 lives left.
I once built a sandrail from scratch. Got it to point I could drive it, WAHOO!!!... trip around block, yehaa, back into garage...ummm, where did I put those brakes at????
Ok, time to install brakes, and fix bent tubing, and repaint. GRRR!!!!
syclonekid43
this is no bull shit. i had the local machine shop redo the sy motor about 5 years back.that motor didnt last more than 500 miles.and my luck my extended warr. was up. so i parked the truck behind my shop till march of last year. when i opened up the bottom half. i found all the rings in the wrong places. i had 5 syclone connecting rods and 1 regular 4.3 tbi connecting rod. i went to see the guy who did my motor and he tells me he never did the bottom half of my motor when he had it. so now i dont deal with him anymore for getting parts for my shop.so if you guys are gonna have a motor done by someone else. find put what kind of work they do. thats where i messed up.
