Falco
Howdy,
I might have the possibility to get Mitcu turbos cheap. However this is still no clear to me. We have the TD06-17g with a 8 cm2 turbine side, right? And we want a TD06H-20g with a 12 cm2 turbine side.
To achive this what should I look for?
1. I guess the TD06 and TD06H have different center sections. Does this mean that I have to change the whole turbo? So a new turbo in that case. What about with the turbine housing? Is it SyTy specific? If not what other cars/truck used it?
2. I heard that some of us used a 20g compressor side with the stock turbine, what do ya think? This way I only need a 20g compressor side. Does it bolt up whit no props?
3. Keep the center section and the turbine housing and give a 20g compressor and a larger turbine wheel. i guess this is not possible, the stock turbine housing can't accomodate a larger wheel, right?
What about with the TD07? Any experience with these?
Any info welcome,
Any info welcome,
