Moates O-meter (knock gauge)
SyTyAddict
I have an O-meter on the way with plans to run it as a knock gauge, does my bin still need to be updated to v23? My bin started as Dig's 60# bin, 1.6_v18 XDF, and TP rt v4.14. I'm about to get into boost tuning and it would be convenient to have the knock info right in front of me. It has the "knock gauge voltage output vs knock retard" settings showing in TP, but I'm not clear if the those setting in this bin are setup correctly for this.
Thanks,
Clay
TYTILIDIE
METH HEAD
Re: Moates O-meter (knock gauge)
Thanks,
Clay
Im glad you asked this because I am about to start doing the same thing.
Yes you will need an unreleased version of code59 to get it to work.
It's just a six
Super Member
I use this http://www.jandssafeguard.com/safeguard.html
It's a bit pricey,,, but so is your engine & you need to protect it.
It has a knock gauge it's adjustable sensitivity, can retard each individual cylinder that is knocking or select all to retard all cylinders even if just one cylinder is knocking.
It has saved my Sy engine many times.
My friend is a distributor for them. His website: http://www.american-pi.com/corvair/corvhome.html His name is Ray
I had a custom A/F ratio face plate made to so the gauge is calibrated to see 9.0 - to 16.0 range & that can be custom made to your likeing also.
I think it's a really great product.:tup::tup:
SyTyAddict
Thanks TwinturboV8ty, that's what I was looking for. Is there a plan to ever release it to the general public or was it an alternative version that got axed?
I had looked at the J&S before, it doesn't seen that unreasonable for the things it does. It's a pretty cool setup.
v23 had other features we were working on that were not fully "tested"/debugged. Just like windows they don't release a new version with every new feature they are building only after a few. One feature we were playing with was a spool up mode, just never got it working right.
Dig is really the only guy that knows the hard code side of things. 1 man band with other priorities in life.
skwayb
NWSTP
I have it up and running. It works rather well. All the information on the circuit, and table setup is there on Code59. Only thing I didn't write up is how to program the moates-o meter. You have to set the high to match your max knock KR and the low to 0.
If you get stuck doing it, post here or code59 and I will help. Also I will need a copy of your bin and I can get it converted to V23.
I had a J&S unit on my Ty.. it works.. but it doesn't retard on what the ECM is seeing. It attaches to the knock sensor input the ecm. That input is PRE ECM filtering so the signal is noise and contains other things that aren't knock. So it will retard when you don't actually have knock if you have it set too sensitive.
SyTyAddict
Awesome! I'm waiting for the O-meter to get here, I'll probably put the circuit together tomorrow. I'll send you a copy of the bin tonight, so you can convert it whenever you get a chance.
SyTyAddict
I sent it to you using a different email this time, I think the other was giving me problems as a result of an small attachment size limit.
johnboy89
Just curious if anybody else besides Paul can do this? I've e-mailed him, but thinking he is busy?
Thanx:)
SyTyAddict
There may be a couple of other that can convert your bin, I'm not sure. When Paul did mine, it took him 2-3 weeks to get around to it, but I was perfectly fine with that, as I was just glad he was willing to help me out. You might bring this up on code59.org if you haven't already, I think Paul might spend more time over there.
You might also check out Scanmaster that is now out, this wasn't around back when I did the O-meter. It's plug and play and does not require code59 to function.
