Mods for 12.99??????
AzBoostin
Just getting into the sy/ty. Picking up a nice typhoon, Wanting to get it into the 12's what are the basic mods to do... so far it has k&n filter, and 3" turbo back exhaust. Can anone give me any tips
JustBeachin
Plays well with others
Re: Mods for 12.99??????
[font=&quot] Here is a list of mods that will put you in the 12s... [/font]
[font=&quot] for less than a grand.
[/font]
[font=&quot] 1) Fuel pump (Walboro 242 / BBK) $100.00[/font]
[font=&quot] 2) Fuel pressure regulator (KB, ATR, ANS, etc...) $100.00[/font]
[font=&quot] 3) Boost controller (ANS in cab adjustable) $200.00[/font]
[font=&quot] 4) High performance chip (ATR street) $160.00[/font]
[font=&quot] 5) Aux IC (Hayden cooler from Pep Boys) $110.00[/font]
[font=&quot] 6) IC pump (Sure Flo from Campers Choice) $53.00[/font]
[font=&quot] 7) Exhaust (Sy-KB / Ty-ATR) $130.00 / $170.00[/font]
[font=&quot] 8) Air filter (K&N in box or on end of tube) $35.00[/font]
[font=&quot] 9) Thermostat (160 degree) $10.00[/font]
[font=&quot] 10) Manual IC pump switch $10.00[/font]
[font=&quot] 11) Torque converter clutch switch $10.00[/font]
[font=&quot] Total $918.00 / $958.00[/font]
[font=&quot] This was the recipe that Ivan the Terrible used to get his Ty into the 12's. I happened to have this off an old hard drive and cut and pasted it. I'm sure others will chime in.
[/font]
[font=&quot]Tuning tools, Datamaster, or equivalent. Fresh Tune-up, etc.....
[/font]
Maybe Search?]
A more update list (in the last 5 years) would be
Before you do anything a fresh tuned up and an older laptop with a scan tool such as Datamster
1) Fuel pump (Walboro) $100.00
2) Fuel pressure regulator (KB, ATR) $100.00
3) Ultimate Chip $400
4) 3 Bar MAP $75
5) IC Pump $100
7) Exhaust (ATR $450)
8) Air filter (K&N in box or on end of tube) $40.00
10) Torque converter clutch switch $10.00
With race gas and good running truck it could run 12.9's. If you tune the truck for alky injection it will run those times on pump gas.
SY2932
Administrator
Also, ditch the metal IC lines that are on top of the motor and replace with 3/4" heater hose.
For the "how and why" to mod, check here.
HotRudyRod
Sorry to butt in but could you explain the advantage of having a torque converter lock up switch and why it works? I know this question should go in the drivetrain section but well i saw it mentioned here and may be AzBoostin doesnt know either, Thanks.
SY2932
Administrator
The advantage of a manual lockup switch is that the torque converter will be locked (ie no slippage) when the transmission shifts into third gear. Therefore it is like the truck is direct drive with all the power from the motor going to the driveline. PRO everyone who has done this mod drops .2 of a sec in their ET's at the track on average. My bud who has a very loose 9/11 TC, which he hates, drops .5 of a sec when he locks his (syclone)... CON because there is no slippage in the converter, this is very hard on it and will shorten TC life. Depends on how bad you want that .2 of a sec. You can see where to tap into the TCC on the ALDL port here. Most folks run a switch that can be gotten to easily to lock and unlock it.
"Autometer mechanical boost and SPA dual gauges (boost, trans temp & fuel pressure, intercooler temp). Also, gauge power switches (to reset max stored values in SPA's) and TCC lock up switch."
Ty 1450
30psi on 93 oct (boom)
Doug,
Where did you get the atr for 170 bucks? I'll buy 2 of those just to keep as spares
12secondSY
Syty Killer :(
I hit 12's this weekend my first time at the track, I ported the mismatch on the exhaust side of the turbo, hotwired the intercooler pump (johnson pump), bellmouthed the intake side of the turbo, bellmouthed the intake side of the intercooler, converter lockup switch, 160 thermostat, conrad cap and rotor, delco cr42ts plugs and atr black beauties wires. Just got my truck last month and still have two origional bald firestone tires on it and two ate up fuzion tires. we iced the intake for an hour the my buddy opened up his almost empty nitrous bottle out of his z28 on the intercooler before the pass. ran a 1.74 60' and a 12.98 quarter at 100. I had about 40 people cheering on the sy at the starting line. my buddy said it hung one wheel off the line but i want to see his video of that. After this sunday I decided to sell my other truck and invest my money in the sy.
supersports10
4) 3 Bar MAP $75
5) IC Pump $100
ok now apply this to a sy, and add a pte52 to the mix....
now what do you think i should run for times??????
SS
JustBeachin
Ty 1450 said:
Doug,
[/font]
